C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
What's it take to get into the 8's on D.R.'s?
Old 07-28-2014, 10:00 PM
usmcpony
usmcpony's Avatar
Default What's it take to get into the 8's on D.R.'s?
So far I have a ECS built grand sport making 780 rwhp on a 6l80E. The car has ran mid 9's on drag radials with this set up.
Mods are:
ECS Novi 1500 kit
Alky kit
Custom cam
Stock bottom end
LT headers and mid pipe
ECS built transmission (Blew up and in the process of being rebuilt...Again...)
What do I need to do to bust into the 8's on Stock size rims and drag radials?
Old 07-28-2014, 10:05 PM
ATLS2
ATLS2's Avatar
A lot more power than 900 whp if you have 19s. IMO
Old 07-28-2014, 10:11 PM
Turbo2L
Turbo2L's Avatar
Drag pack, drop the stock axle back, remove the passenger seat, a 1.45 60', and a 125 shot.
Old 07-28-2014, 10:41 PM
joe11204
Procharged F1X 7.18 @ 197
Support Corvetteforum!
joe11204's Avatar
St. Jude Donor '09-'10-'11
Mods are:
ECS Novi 1500 kit
Alky kit
Custom cam
Stock bottom end
For starters those wheels are not helping at all. You can run a 16 when at the track and switch back to 19 when on street.
Old 07-28-2014, 10:55 PM
usmcpony
usmcpony's Avatar
The reason behind this is cause I want to drive my car to the track and I want it to run 8's as it is without switching wheels and tires.
Old 07-28-2014, 11:10 PM
ATLS2
ATLS2's Avatar
I run streets with 17s. A lot more traction than the 19s.
Old 07-28-2014, 11:34 PM
Frans96ss
Frans96ss's Avatar
St. Jude Donor '09
I have done it plenty of times... Just need the right combo.
This car has ice cold AC and is on an 18 inch drag radial. Since video car has gone 8.69. more times coming on friday at cecil.
Also your combo will be close to doing it but that trans will never go 8's
Old 07-28-2014, 11:36 PM
usmcpony
usmcpony's Avatar
Your car is what inspired me to do this.
Old 07-28-2014, 11:42 PM
Frans96ss
Frans96ss's Avatar
St. Jude Donor '09
I honestly really appreciate that. We are making a few changes and hitting the track friday
Here is the last track outing
Old 07-29-2014, 12:04 AM
camirocz
camirocz's Avatar
Powerglide!!!!!!!!!2 speed.
Old 07-29-2014, 01:13 AM
Milan
Milan's Avatar
I don't see 8's happening on a novi 1500
Old 07-29-2014, 01:14 AM
usmcpony
usmcpony's Avatar
I didn't say I had to keep it
Old 07-29-2014, 01:19 AM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Drive to the track on a 15. I will and plenty of others do.
4l80 or PG swap, good convertor, and ~950-1000rwhp with good traction should do it.
Milan
Milan's Avatar
new blower and 15's in the rear and you are there IMO
Old 07-29-2014, 08:33 AM
croatbob
croatbob's Avatar
glide, 15s and bigger snail!!
Old 07-29-2014, 08:50 AM
joe11204
joe11204's Avatar
I can absolutely respect that. Having a goal with challenges makes it all that more exciting when you accomplish your goal.
If you could make a small change at the minimum I would go with an 18" wheel/tire combo and a larger blower.
That should put you right on the door of 8's.
Old 07-29-2014, 09:45 AM
Unreal
Unreal's Avatar
The bigger blower and the extra 150-200rwhp is going to need a lot more than just a bigger blower though. Bottom end, fuel system, etc.
To What's it take to get into the 8's on D.R.'s?
Old 07-29-2014, 09:57 AM
joe11204
joe11204's Avatar
I would imagine the fuel system and all the supporting items etc, goes without saying to support the increase in hp.
But then again, the op didn't say he wanted it to last.
Old 07-29-2014, 10:39 AM
Frans96ss
Frans96ss's Avatar
St. Jude Donor '09
But BEFORE all that guys..... He needs a trans..... I have a 4l80 conversion if he is interested
Old 07-29-2014, 11:51 AM
Unreal
Unreal's Avatar
True.
People saying just slap a bigger blower and tires on, it isn't that simple. There is a lot of supporting parts to do it.
Would be like saying take a stock vette, slap a Ysi, glide and some tires and you have an 8 second ride. It is a bit more complicated than that.
Quick Reply: What's it take to get into the 8's on D.R.'s?
