Fuel smell..... ideas ??
I know it is impossible to troubleshoot an issue like this on the internet, but I am looking for any ideas of what to look for or check.
Mods are in my signature. I recently added an ECS stage 1 fuel system to my car. Since adding this there is a constant smell of gas when the car is parked overnight in my garage.
I have checked, double checked, checked 1000 times and can not find any leak of any kind anywhere. The smell started right after adding the fuel system and no other changes were made at the same time. Someone suggested to me the certain fuel lines can allow an odor right through the line. I emailed ECS asking about this but never got a response. Has anyone experienced such a thing. I seems unlikely but I am totally out of ideas to check.
Thanks for any suggestions.....
Thanks. I am going to have to assume its the hose, since I cant find anything else. I am a little disappointed the hose supplied wasn't better. I would have happily paid extra for a better quality rather than having to redo the lines now.
http://www.jayracing.com/fuel-fittin...ting-p-39.html
I don't think you're getting the odor permeating a hose. Has to be a gasket or vent above the fuel level.
Happened to me before check the inline fuel pump shims if its leaking replace it with o-ring. check both fuel pump ports
Select our PTFE hose if fuel smell cannot be tolerated. Aeroquip Startlite hose may weep fuel smell.
It seems Teflon is the way to go.
That's interesting Fore calls out the startlite specifically because it seems like awesome stuff. I wonder if e85 has less smell.
I am just researching the issue on line and one post I read the guy says his smells with regular gas and not with E85, so I guess it does have less odor.
The more I search the more I see this is a very common issue. I wish I had known about it before but at least now I am pretty sure what the issue is. Luckily, on the ECS system there is not much fuel line involved. I will change it all out to Teflon when I have a chance.
http://forums.corvetteforum.com/c6-f...el-system.html
Think I am going to go with this line when I make the change.
http://www.techafx.com/catalog/49
After some research you may be on to something about the hose. Not sure why any manufacturer would produce a hose that could weep gas odor. Seems like Fore should eliminate one hose and simply use the teflon lined!
I'm guessing it's the cost and because the Teflon line seems to need special fittings and be a little more work to put together. I will never use anything besides PTFE again. My garage smells like a gas station.
When you get into the cost of what we can end up spending, the cost of a hose should be a minor detail if it's necessary. Hope you eliminate your problem.
I used to run the ECS fuel system. I ripped it out cause it smelled like my garage was gonna blow up if someone lit a match. It was ridiculous given the cost.
I went with all PTFE, and the smell is 100% gone. The fittings are kind of a pain in the rear, but after you've done a few of them the rest fly together. It's well worth the additional 150 bucks.
