?'s on Centrifugal S/C
Recently I raced a gsxr 600 back to back to back. No cool down no methanol just the standard ecs 1500 kit on 10 psi. The outcome of every race was actually better for me. Each run I pulled harder on the bike. If I were getting heat soak it was not affecting me at all. Temp outside was around 90 degrees and a ton of humidity. Just my experience with the ecs kit and heat soak.
When I get back home I can check the logs for iats as I do not remember off hand what they were.
