C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
What's needed to drop a walbro 450 into the stock fuel bucket?
Old 07-19-2014, 01:47 PM
turbotuner20v
turbotuner20v's Avatar
Default What's needed to drop a walbro 450 into the stock fuel bucket?
I'd like to upgrade my stock pump with a walbro 450 to work in combination with the magnafuel 4303. Can I just drop the walbro 450 into the stock bucket with a little cutting and the racetronix fuel pump harness. Any wiring to be aware of that isn't plug and play? I'd love to see some pics or hear some experiences. Also, are people using a particular source for the pumps?
Old 07-19-2014, 07:43 PM
turbotuner20v
This looks like some good info:
Originally Posted by Racetronix
We do not include a filter sock or wiring with our F90000267 pump b/c not everybody requires the same hardware. We have adjusted our price to reflect this. Customers can use our FPWK-017W harness kit to install the F90000267 pump but they will have to change one end of the in-tank harness (which is Teflon 14 Ga.) which has a standard Walbro-style GSS connector to the Delphi RCS-057 listed in our web store. We recommend the FFS-250G filter sock, FFT-150 fuel tube, OCLMP12.3 and OCLMP13.3 clamps for installation.
A few IMPORTANT notes worth mentioning here:
1. The factory return system / regulator can NOT handle the fuel volume of the F90000267 and F90000262 pumps so a rail-mounted regulator with -6 Teflon return line will be required. Running the system without this will cause a major pressure rise and premature pump failure.
2. This F90000267 and F90000262 pumps will not support the factory jet-pump system incorporated into the fuel module so holes will have to be made in the module. Disabling this system means that the bucket will not fill above tank level and b/c there is no baffling in the tank an adequate level of fuel will be require to prevent the pump from running dry esp under agressive driving which causes the fuel to slosh around in the tank.
Old 07-19-2014, 09:15 PM
chriswood
chriswood's Avatar
I just put one in my car. Unfortunately I didn't take any pictures. As long as you don't mind putting holes in your stock can it's not a problem. The pre filter is different but it's not an issue. I drilled a lot of 1in holes in the can and removed the majority of the bottom.
Old 07-19-2014, 09:21 PM
chriswood
chriswood's Avatar
Also the only wiring involved is I cut the connector off the 450 and soldered it to the leads for the factory in tank connector. This is where I bought mine. http://m.ebay.com/itm/170945680470?nav=SEARCH
Old 07-20-2014, 01:11 AM
boostaholic786
boostaholic786's Avatar
Just curious how much of a difference is this compared to a boost-a-pump setup? Just bought my D1SC-1 LS3 M6 with all supporting mods with a boost-a-pump and 80# injectors.
Old 07-20-2014, 09:41 AM
turbotuner20v
The 450 is designed for e85 and should support ~700hp. The stock pump with a boost a pump might support 550-600hp on e85 if the pump lived. E85 killed my brand new z06 pump in a few hundred miles. My external magnafuel does most of the work, so I just want an e85 friendly pump that will drop in and also flowa decent amount.
Old 07-20-2014, 09:44 AM
turbotuner20v
That link didn't show up on my phone, sounds like what you cut and soldered I could use that racetronix quick connect for. Glad to hear it drops in pretty easy, any fuel pickup issues with the modified bucket?
Old 07-20-2014, 10:16 AM
Blackonblacksls
Blackonblacksls's Avatar
Couldn't have been just e85 that caused the problem. Lots of people use e85 in z06 cars with no issues.
Hell my 120k mile z06 pump takes e85 just fine..
If you got a magna fuel I would just use a stock pump. Not worth the possible captivating trouble to deal with holes in a factory bucket. Especially in an e85 street car. Because I would think you run around empty or close to it on a regular basis.
Old 07-20-2014, 04:18 PM
turbotuner20v
It seems like oem pumps either die right away or live forever on e85, at least from what I've found. It wouldn't hurt to have some extra pump for my power goals anyways, so I'm pretty set on the 450. How much does having the modified bucket impact fuel? I'm headed to the gas station as soon as I hit a 1/4 tank already.
Old 07-20-2014, 06:10 PM
chriswood
chriswood's Avatar
The wiring I was referring to is the actual power and ground wires in the tank. The 450 will come with a connector already on it that will have to be cut and soldered to the factory in tank wiring. I also use a racetronix harness for the exterior wiring. I use the 450 in tank as a primary pump and a 4303 y'd into the same feed off a hobbs. Also I've had no issues, just be conscientious of the fuel level to prevent any over heating/ cavitation of the pump.
Old 07-20-2014, 09:51 PM
turbotuner20v
Nice, sounds like exactly what I'm doing
Old 07-23-2014, 03:19 PM
turbotuner20v
racetronix is kind of hard to get a response from.... I'm trying to understand if I need the harness they listed, or if that's for an older f-body or something...
I'm picturing the C6 harness below running the direct wire from the alternator to the top fuel pump assembly plug outside the tank.
C56 Fuel Pump Wiring Harness - FPWH-008 - $59.99
Then I'd leave the connector on the Walbro pump so it would attach to this new one:
Fuel Pump - 430L/Hr, E85 Turbine HP - F90000267 - $139.99
Connector Set, Fuel Pump / Hobbs Switch - RCS-057 - $2.50
Then I'll cut the wires off my existing fuel pump and that new connector will attach there inside the bucket and the original plug will still connect to the top of the internal fuel assembly?:
Does that seem right? I like the idea of using that connector vs. soldering wires together in the pump assembly.
Old 08-01-2014, 12:33 AM
turbotuner20v
Just FYI, for anyone who uses this thread in the future, buy the next 1 or 2 sizes up on the fuel tube. 150mm is a bit short.
theandrewo (03-20-2019)
Old 08-06-2014, 09:30 PM
walhan_qtr
Support Corvetteforum!
walhan_qtr's Avatar
I have one in my car, I don't think there is a lot involved in the install as mentioned earlier. I never took pictures even though I saw one being done just few weeks ago on my buddy's vette. I will next time.
and yes some stock pumps works fine and some don't. I went through 3 factory pumps. I think one was within few days!!! I forgot how long exactly but I posted about it so you should be able to find it. It would be stupid to go through all the trouble of doing a pump swap only to put a stock one back in it (I did it three times, and wish I just did the E85 pump the first time, what awaste of time and money!!)
Old 08-07-2014, 11:45 AM
Smoove
Smoove's Avatar
I haven't done the swap yet in a vette but, maybe some dimension info would help....maybe not. I'll just leave this here in case. I do have some stock fuel setups for vettes, maybe when I get a chance I will grab a 450 and see what I have to do to make it fit. Unfortunately the setups are up north where my car is..so for now, only measurements.
aeromotive vs 450 walbro
Old 10-21-2014, 01:02 AM
telly444
telly444's Avatar
so can we get away with just dropping in the 450 without changing the regulator or return system? would a walbro 400 be a better choice?
Old 10-21-2014, 02:10 AM
C6 Curtis
C6 Curtis's Avatar
Yep drops right in. Just a PITA drop the tank.
-Curtis
To What's needed to drop a walbro 450 into the stock fuel bucket?
Old 10-22-2014, 06:22 PM
boostaholic786
After doing some research and talking with the guys over at Advanced Modern Performance, the stock pump will fit but again, has to be modified and I'm not sure you can get away without soldoering. I'm personally about to do a full fuel system with a triple walbro 255 inline along with new lines/hoses rated for E85 so I dont have any issues with E85. I just bought ID2000 injectors which is more than enough to support the fuel I need, maybe overkill but you never know what I might do in the future so better to do it right the first time than to go back and redo it. Alot more cost efficient IMHO...
Now one thing Iam worried about is once my car is tuned for E85 which is very available here in Texas everywhere, but once the temps drop and they go as low as E70 (Some people say that Texas stays E85 year round and others say they have seen it go as low as E70) how is that going to affect the tune? especially if its tuned for E85....
Old 10-23-2014, 10:58 PM
RMA_C6
RMA_C6's Avatar
Here is how I did my 450.
Old 10-24-2014, 04:25 PM
0Shane@CountyCorvette
Former Vendor
Shane@CountyCorvette's Avatar
Pick up a FlexFuel sensor kit from DSteck and have it installed. With a properly setup tune and the FlexFuel sensor, your tune will adjust accordingly to the ethanol content. So no worries there!
-Shane
Quick Reply: What's needed to drop a walbro 450 into the stock fuel bucket?
