C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
What's needed to drop a walbro 450 into the stock fuel bucket?
Old 08-02-2017, 05:05 PM
  #121
Whis9
Whis9's Avatar
any new updates?
tips or tricks
Old 08-02-2017, 05:43 PM
  #122
EnviedC6
EnviedC6's Avatar
Originally Posted by rio95
Why are u running a return line? I haven't figured out why some people do yet most don't? Why would u of it isn't necessary?
It is mainly for cooling. Once you hit say 750-800rwhp, the fuel supply needed is vastly increased. So to increase the supply you run the pumps harder. This increase in volume, will dead head when not used, creating pressure and heat. Any fluid movement that isnt doing work will create heat. By returning back to the tank it can cool down.
Old 08-02-2017, 06:29 PM
  #123
rio95
rio95's Avatar
That makes sense thanks.
A lot of big power setups run multiple pumps though where the additional pumps only come on when needed so I don't see how that would deadhead and create excessive.l heat. I guess your explanation only applies when you can't get fuel flow rate below some point due to the size of the main pump.
Old 08-05-2017, 07:37 AM
  #124
Ls240sx
Ls240sx's Avatar
I dont know that this helps anyone but a Racetronix 680lph e85 setup fits in the stock bucket
Old 08-13-2017, 11:51 AM
  #125
asd_srt
asd_srt's Avatar
what all did you have to do to make this work?
Old 08-13-2017, 12:24 PM
  #126
Ls240sx
Ls240sx's Avatar
Just enlarged the hole where the pumps stick through.
Old 08-13-2017, 05:12 PM
  #127
asd_srt
asd_srt's Avatar
awesome, everything else connects like stock?
Old 08-13-2017, 05:34 PM
  #128
Ls240sx
Ls240sx's Avatar
Yes. One thing to remember is that the Zr1 has no regulator so the fuel pressure is regulated by the fpcm. Also, this assembly is $1400 new, so might be a bit reduculous to find one to use in the first place.
Old 08-15-2017, 12:56 AM
  #129
romandian
romandian's Avatar
how do 680 lph get into the bucket?
Old 08-15-2017, 07:56 AM
  #130
Ls240sx
Ls240sx's Avatar
They just fit. The bracket the Racetronix pumps are attached to happens to be the exact size of the bucket. Socks and everything just slide it.
Old 08-15-2017, 08:32 AM
  #131
romandian
romandian's Avatar
actually i was thinking about how that much gas would get in.
Old 03-23-2018, 09:33 AM
  #132
heddde
Cruising
heddde's Avatar
1. Drill holes in bucket
2. connect wires
3. Dont need the Tiny small tiny hose
4. Dont need any regulator or block off
5. Let the filter hang outside bucket
6. Change the bigger hose to a submersible E85 hose
Ready to rumble?
Old 03-23-2018, 10:04 AM
  #133
helga203
helga203's Avatar
Default ??
Boy you would hope he had it done by know. Post was 2017
Old 03-23-2018, 10:06 AM
  #134
heddde
Cruising
heddde's Avatar
Default ??
This was a question from me to all that have the answer !
Old 01-31-2023, 11:41 AM
  #135
pierrel
pierrel's Avatar
Been a few years now since this thread was started
Has anyone confirmed the runaway fuel pressure issue that racetronix mentions?
On E85 and on 93 octane fuels.
Any users who has had a failing pump or fuel pressure regulator?
Old 02-01-2023, 07:34 AM
  #136
injfuel
injfuel's Avatar
have a walbro 450 in mine. Bottom cut out of the fuel pump hat. No issues with fuel pressure and been running it for 3-4 years. Car is flex fuel and I run pump and e85 through it.
pierrel (02-02-2023)
Old 02-02-2023, 12:38 PM
  #137
pierrel
pierrel's Avatar
Great, appreciate you sharing your experience!
Quick Reply: What's needed to drop a walbro 450 into the stock fuel bucket?
