C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
What's needed to drop a walbro 450 into the stock fuel bucket?
Old 12-02-2014, 06:49 AM
  #41
KLLRVET
KLLRVET's Avatar
Does anyone know what ID hose is needed? Will this work: http://www.jegs.com/i/Gates/465/2709...FVFk7AodziAAtg
Old 12-02-2014, 03:26 PM
  #42
ironhorse583
ironhorse583's Avatar
im pretty sure its the 5/16.. http://www.jegs.com/i/Gates/465/2709...ductId=1534981.. i can let you know for sure when mine comes in
Old 12-02-2014, 04:12 PM
  #43
fastdiesel
fastdiesel's Avatar
Originally Posted by ironhorse583
so what i hav gathered from this thread so far is - if only installing one 450 pump
the stock car harness will support the pump. the racetronix harness is unnecessary
no need to upgrade the wiring inside the bucket.
no need to install an aftermarket regulator or add a return line
get the 200mm tube bc the 150mm is to short or get a submersible fuel hose- comes precut to 12 inches
the stock bucket needs to be modified
drop the tank. pull the stock pump assembly out. remove stock pump. install the 450 pump which involves bucket modifications. install pump assembly back in tank. install tank back in car.
is this all correct so far.??
if you can post some pics of your install.caused i would like to do the same thing.thanks
Old 12-02-2014, 06:23 PM
  #44
C6 Curtis
C6 Curtis's Avatar
I did not modify my bucket at all. Most i had to do was connect the wires and replace the small fuel line inside.
-Curtis
Old 12-03-2014, 02:04 PM
  #45
ironhorse583
-Curtis
you must of added some holes..? have any pics.?
im still working on mine but this is what i have so far..the red circle shows the stops i shortened. they allow the inner plastic piece to be lowered. the corrugated hose i got from racetronix is a bitch to get on. i ruined the 1st one. i have another on order as well as a submersible hose. i can post more pics when i get more parts
Old 12-27-2014, 11:14 PM
  #46
ascastil
ascastil's Avatar
Originally Posted by RMA_C6
Here is how I did my 450.
Attachment 47835792
What do I do with the small line coming off the side of the bucket in this pic (the attachment)? The new 450 pump doesnt have a spot to plug that into.
Old 12-28-2014, 12:21 AM
  #47
RMA_C6
RMA_C6's Avatar
I cut it off.
Old 12-28-2014, 05:38 AM
  #48
ascastil
ascastil's Avatar
Any confirmation if its 5/16 hose? Ill go ahead and buy this hose if someone can confirm it for me. Thanks.
Old 12-29-2014, 07:20 PM
  #49
ironhorse583
confirmed to work
Old 01-02-2015, 05:00 PM
  #50
SHovV
SHovV's Avatar
Interesting thread
Old 01-04-2015, 12:18 PM
  #51
curtisb23
curtisb23's Avatar
Thinking about doing a 450 also
Old 01-05-2015, 12:17 AM
  #52
ascastil
ascastil's Avatar
I cut it off.
Isnt that hose for the venturi? I was reading that the venturi helps fuel get to the other tank. How will that work now that Ive cut it off?
One more question. Does the 450 have a built in check valve?
Old 01-05-2015, 12:53 AM
  #53
narfdanarf
narfdanarf's Avatar
I believe the small line is a bypass line that is used to keep the bucket full. 450 does not have an internal check valve AFAIK. I had to add one to keep my pressure up after shutoff so the car starts easier.
Old 01-05-2015, 03:05 AM
  #54
ascastil
ascastil's Avatar
Perfect! Thankyou!
Old 01-07-2015, 02:56 PM
  #55
n_brio
n_brio's Avatar
Can some one please messure the resistance on the walbro 450 pump? How many ohms?
and can someone please help me this this -> https://www.corvetteforum.com/forums...fuel-pump.html
Old 01-08-2015, 04:18 PM
  #56
UniTink72
UniTink72's Avatar
I've been doing a lot of reading on this and would like to clarify/confirm my understanding in two areas:
1. Modifying the bucket. It looks like since you guys put (fairly large) holes in the bucket and talk about cutting the line shown below (orange arrow), that the drivers side venturi pump will now be disabled. Is it really impossible to mount the pump inside the bucket such that this system is kept intact? I've also read that the walbro 450 pump itself has no connection for this line, but from the diagram below it looks to be part of the fuel lines, not the pump.
2. Adding a return line. I'll be doing this to maintain control over the fuel pressure. This means I have to put the caps on BOTH regulators right? One in each tank. Also, when you run the new line, how do you plumb the return back into the tank? Put a new hole and fitting in the top of the gas tank?
Thanks for your help on this guys. Lots of excellent info here.
Old 01-08-2015, 05:18 PM
  #57
turbotuner20v
turbotuner20v's Avatar
The 450 pump doesn't include the tiny line that draws fuel into the bucket, therefore it's necessary to cut the bucket open to expose the pump inlet to a good fuel source. The pump inlet is mounted so low that sloshing shouldn't be a huge concern, but it will be different than when the pump pulled fuel from the pre-filled bucket.
The plug is needed on the driver side. You're replacing the internal regulator with a block off because you're adding an external regulator in its place.
The regulator on the passenger side simply controls when the siphon works. It's set to transfer fuel between tanks at ~54psi. If you need to run your externally regulated fuel base pressure below 54psi you need a bypass (not block off) that will allow fuel transfer below 54psi
To What's needed to drop a walbro 450 into the stock fuel bucket?
Old 01-11-2015, 08:59 PM
  #58
KLLRVET
KLLRVET's Avatar
Unitink72 how do you "plug" the stock regulator? I'm encountering elevated fuel pressure, and Id like to mod the stock bucket to plumb a return
Old 01-11-2015, 09:08 PM
  #59
ironhorse583
u dont actually plug the stock regulator.. u replace it
i used
http://www.lingenfelter.com/mm5/merc...egory_Code=C78
for the retun line i uses the ECS sump..
Old 01-11-2015, 09:38 PM
  #60
KLLRVET
KLLRVET's Avatar
Thanks for the link to the plug. I have one ordered now.
Ive been searching, but I cant find anything about an ECS sump. Do you have a link for that too?
Quick Reply: What's needed to drop a walbro 450 into the stock fuel bucket?
