08 Coupe Magnuson Pulley Swap Update
Hey Guys ... Just got done yesterday pulley swap on 08 Coupe with Magnuson S/C... Arun @ Dasilva Motorsports of course worked his magic again...Car pulls down low in the rpm's and doesn't let go...Definetly say for a street car it's way more than enough !!! Numbers from dyno 565 rwhp - 535 rwtq ... on 10 PSI ... Thanks to the guys again and yourself Manny for making this happen...
2008 Corvette Coupe Automatic...Magnuson Heartbeat unit ... LG Motorsport header package - Borla Type S ... Installed a 81mm pulley...96mm I believe was on... Car pulls hard...
I can guarantee you that you're having a HUGE amount of belt slip. You should be way over 10psi with the way you're set up. My rig is an LS3 with Heartbeat, blower cam, 81mm pulley, and all the bolt ons. My boost peaked in the high nines at 3500 rpm and went south shortly there after. It should have held in the mid nines from 4000 on up. I changed to a shorter "Gatorback" belt and all is good now. IIRC, it's a 96.7" Gatorback belt. Change to that belt and you'll get your boost back. I'd bet you'll be in the 12psi range. You might check with your tuner before going WOT with the new belt.
See if he logged the boost on the dyno runs. I had a 97" belt on mine that was about the smallest I could fit on there. Lots of slip. My boost went down to 6psi on the top end. I didn't think I had belt slip either. No obvious signs of it and the thing still pulled hard on the top end.
You might check the coolant hoses that are above the tensioner. My original belt would stretch enough, under load, that the tensioner came up high enough to touch one of those hoses. It cut two nice grooves in one of them.
640's with the slip ... Will only imagine... with what I have now I am happy with... Met a guy last Thursday at the speed shop with a 08 Z06 and 1000 rwhp... frigging insane...When is really enough for the street ... Your car should be the insane category ...
