Please do it with yours!!
I have the same setup with dual fan and dewitts radiator,,, the heat is killing here especially in traffic and even at midnight you still over heat!! (currently the temperature is 110F)
Tom, this is good and we hope the cooling effect will be doubled
Mine came in today . Not a dual kit, just the single fan. We are going to have to set it all up as I believe this is one of the first to be installed in a C6. The shroud is beautiful!
No seriously, the stock fan had quite a bit of space between it and the radiator. This will sit almost right up against it.
I wonder what the c5's will look like doesn't seem like much space but I forget it's tilted. Looking forward to your results and hopefully one of the c5 guys have results soon
So does that aluminum part stay on or is that just for shipping? I would order 2 right now if they would just swap into the spal dual fan setup I have now mounting wise. Wiring is easy enough.
To my understanding, there is no current dual fan setup with these new brushless fans, nor will there be for the time being. They don't fit. The dual spals are like 11" fans, while this one I believe is 17", you couldn't fit 2 of them...
That is correct. They also make 12" (which have a 13" mounting circle) and those won't fit anything either. That is why we are going with the single 17".
