finally going to ditch the stock fuel rail... what are people using?
My stock LS3 fuel rail has supported 937+whp on E85, but I have to imagine I'm at the limit
What aftermarket rails are people running?
Do they clear the firewall without any issue?
I'm looking to run a -8AN to the rear of the passenger rail, -8AN cross the front, then -6AN out the back of the driver rail to my regulator. The only part that seems complicated is the fittings at the rear of the rails if space is tight and the rails aren't the correct length.
I run the Holley Rails on a stock LS3 manifold.
http://www.holley.com/534-209.asp
RSI rails but I had Dallas Performance ones for awhile and they were much nicer and would do those if I had to change. I was dumb for selling them.
Nasty nate rails are suppose to be nice too.
Dallas Performance actually said they don't sell them anymore. Only available for local install on site.
The only banjo fitting I can find is a -06AN to a -08AN. Is that what you used?
http://www.summitracing.com/parts/aei-15636
So I'd need to reduce to -06AN... does that impact flow enough to limit the improvement of going w/ an aftermarket set of rails?
Jeff I just bought the Dallas performance rails just before TI?? But anyways I will tell you they are made exactly like the Wilson Billet rails very nice. I used a O-ring 90 hose end so I didn't have to modify the fire wall and didnt have a hard 90 because I don't like the presure drop you get from hard or machined 90's not to say it won't work fine, because a lot of ppl use them with out issue its just my over engineering mentality. I have several sets that I own and have used so if you want to chat give me a ring. Or you can just pick up what you want. GL!
http://www.ebay.com/itm/Aeroquip-AN-...-/360571399552
