C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
8 Second Street car C6Z (Video)
Old 07-16-2014, 11:30 AM
  #41
1MEANGS
1MEANGS's Avatar
Solid pass... That car is a Monster!
Old 07-16-2014, 08:23 PM
  #42
ajrothm
ajrothm's Avatar
Received 1,095 Likes on 746 Posts
Hey Fran, what pulley is on it? velocity stack? Killer pass...
Old 07-16-2014, 10:38 PM
  #43
Frans96ss
Frans96ss's Avatar
St. Jude Donor '09
We just put a 4.250 on it. Still through the air filter.... Street car
Old 07-17-2014, 01:57 PM
  #44
ajrothm
ajrothm's Avatar
I run the same 4.25" pulley on an F1R, running thru a 4" pipe/air filter and you guys are 9 mph faster.... I think I'm doin it wrong...
I just tightened my converter so I think Ill go 153 or so thru the filter...Maybe 154-155 thru the velocity stack... Still 5 mph slower then yours..... I'm thinking the PG is making all the difference... Less parasitic loss...
I'd kill to have your MPH with this F1R....I wouldn't even think about swapping blowers if I could run 160.....
Old 07-17-2014, 02:12 PM
  #45
Frans96ss
Frans96ss's Avatar
St. Jude Donor '09
What gas are you on? And how much timing?
Old 07-17-2014, 08:55 PM
  #46
usmcpony
usmcpony's Avatar
That's a sick ride
Old 07-18-2014, 06:43 AM
  #47
ajrothm
ajrothm's Avatar
When it went 151 mph, I was on 93/meth (M15/M10 nozzles), thru the air filter. Timing was 15*. Converter was a little loose at 11.5%. Now the converter is tightened (not sure what the % slip is yet).. Raceweight is right at 3610lbs
Next time it goes to the track it will be with the velocity stack on, Q16 and 17* timing... shooting for 8.90@155... That's if I can get +1000' DA or better...and if the rear end stays together...
Old 07-18-2014, 08:52 AM
  #48
Frans96ss
Frans96ss's Avatar
St. Jude Donor '09
Up your timing.... Esp if it takes it. 15 degrees on pump and meth is ok but a tad low. All depends what the car likes but if its getting no knock creep up on it.
Im at around 20 depending on how hot the AIT's get during the pass and pull some out.
I dont think you need Q. Try C first. and creep up on the timing.
Old 07-18-2014, 12:43 PM
  #49
ajrothm
ajrothm's Avatar
Yeah C16 is definitely safer...
I've been as high as 17* on the dyno with 93/Meth with no KR, 100* IAT....But I wouldn't trust it on actual street/track pulls with that.
Bret told me he has ran them as high as 20* on Q16 or MS109 and made some good mph gains..
I will try to bump it some next trip out if the traction/DA is there.... I don't want to get greedy and hurt my perfect running engine, but I'd love to get closer to 160 mph... (hell I'd settle for 155 mph at this point).
Thanks for the info!
Old 07-18-2014, 02:22 PM
  #50
08C6
08C6's Avatar
Badass street car for sure... Nice numbers bud !!!
Old 11-18-2014, 02:54 PM
  #51
Frans96ss
Frans96ss's Avatar
St. Jude Donor '09
Took this car again last week after some changes.... Car is simply flying
We added a 100 shot to the car.
This is a boost only run
We also added the new Big procharger intercooler for C6
Old 11-18-2014, 04:42 PM
  #52
robz
robz's Avatar
Nice going!
Old 11-18-2014, 06:03 PM
  #53
usmcpony
usmcpony's Avatar
Is this car still making 840hp or something like that?
Old 11-18-2014, 07:09 PM
  #54
SJ-KY
SJ-KY's Avatar
Great work!! You still on stock diff and gear?
Old 11-19-2014, 09:39 AM
  #55
Frans96ss
Frans96ss's Avatar
St. Jude Donor '09
Originally Posted by robz
Nice going!
Thank you
Had it on the dyno the other day and boost only it made 868. I only made one dyno pull bc i do most of the tuning at the track
3.42 gear yes. Stock diff with 300m shafts.
Old 11-19-2014, 08:20 PM
  #56
usmcpony
usmcpony's Avatar
It made 868rwhp when you ran a 8.20 or was that with 100 shot as well? Im trying to setup up my car. That's why im asking. Thanks again
Old 11-19-2014, 10:07 PM
  #57
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
868rwhp through an unlocked big stall powerglide is worlds apart from 868 in a locked converter, or manual car. That is easy 1000+ on a manual.
To 8 Second Street car C6Z (Video)
Old 11-20-2014, 08:15 AM
  #58
Frans96ss
Frans96ss's Avatar
St. Jude Donor '09
Boost only like i said in the above post.
Old 11-20-2014, 04:56 PM
  #59
usmcpony
usmcpony's Avatar
You mentioned boost only above the 8.5 run specifically and not that 8.2 run. I wasn't sure. That's why I asked.
Old 11-20-2014, 05:14 PM
  #60
usmcpony
usmcpony's Avatar
Your other thread that you just posted you said it ran a 8.57 on boost and a 8.21 on 100 shot.
Quick Reply: 8 Second Street car C6Z (Video)
