***RSD All Aluminum Radiator***
Anyone who wants their LS engine to run cooler should put one of these in their car and replace the thermostat reprogram the fans to reep the benefits of a cooler engine.
We also build a 3" cut down radiator for the Vortech and Procharger supercharger guys. With the 3" cut down unit you can use a 4" air filter pipe to increase boost in your supercharger instead of the restrictive plastice dongle.
All of our radiators are available with either oil coolers or Transmission coolers.
Buy them here;http://www.racespecialtydesigns.com/home.php
Steve
Steve@RaceSpecialtyDesigns.com
Steve
Were you ever able to figure out a dual fan set-up ?
I am in the middle of my twin turbo build and am interested in the 3" cut down model just in case I ever switch to a supercharger down the road but I want to run dual fans that fit the radiator correctly.
Anyone who wants their LS engine to run cooler should put one of these in their car and replace the thermostat reprogram the fans to reep the benefits of a cooler engine. Here is a comparison of the Stock Radiator to ours. More than double the thickness and capacity!
Steve
Steve
Steve
Steve
We also build a 3" cut down radiator for the Vortech and Procharger supercharger guys. With the 3" cut down unit you can use a 4" air filter pipe to increase boost in your supercharger instead of the restrictive plastic dongle.
Email me Here ;
Email me Here ;
