Dewitts radiator cut down question
I have a 09 zo6 looking at buying the cut down with the EOC/ TOC has anyone installed this on their Zo6? Any particular modifications had to be done to the EOC line?
Works better with z51 or custom lines but stock can work. Need the fittings off stock oil cooler.
I use the Z51 hoses as they are made to fit the radiator cooler, Not the front mount air cooler. It will not matter if it is cut down version or normal version.
