C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Looks like its 8 or 10 rib time
Old 02-01-2014, 08:10 PM
jon6.0
jon6.0's Avatar
Default Looks like its 8 or 10 rib time
My 6 rib with DP direct drive isn't liking the 2.87" blower pulley.
I tried tightening the belt today and only saw 12.5psi up top. I don't want to crank down on it too hard for fear of messing up the water pump. I'll be talking with Josh at A&A about either doing an 8 rib or 10 rib. I'm leaning toward 10 rib if I'm going to spend the money. At least I only have to do the crank pulley, blower pulley, and a couple of idlers. I may do their upgraded bracket since taking the blower off to change a belt is a pain in the rear.
Old 02-01-2014, 08:14 PM
ajrothm
ajrothm's Avatar
Received 1,095 Likes on 746 Posts
Do the 10 rib for sure if going to the trouble. That way when you switch to a YSI next year, your ready for it. You may have to space the rack forward to clear the 10 rib. Not sure on a C6 but on a C5 you do. Just FYI.
Old 02-01-2014, 09:56 PM
playtoy
playtoy's Avatar
Aahhhh, the beauty of a C6. You won't have to space out the rack. I have a 50mm cog on mine and the rack is in they factory location. It's tough getting the belt between the pulley and the rack but it fits.
Old 02-01-2014, 10:00 PM
jon6.0
jon6.0's Avatar
Nice! No reason not to do a 10 rib then. I think the 10 rib balancer is only a few bucks more.
Old 02-02-2014, 12:32 AM
Detoxx03
Detoxx03's Avatar
I agree with doing 10 rib.
Old 02-02-2014, 12:41 AM
gotjuice?
Support Corvetteforum!
gotjuice?'s Avatar
St. Jude Donor '13
While you are doing the 10 rib, Change the a/c drive to the 6 rib.
Old 02-02-2014, 01:09 AM
jon6.0
jon6.0's Avatar
What's needed for that?
Old 02-02-2014, 02:38 AM
Detoxx03
Detoxx03's Avatar
Talk to ECS about it.
Old 02-02-2014, 01:15 PM
edge04
edge04's Avatar
I'm about to buy a flip drive kit and figured I would also add the tensioner and upgrade to more ribs, sounds like might as well go with 10. I am new to corvettes and have a 2006 z51. How much of a PIA is it to swap the crank pulley. What else should I do while there...radiator?
Old 02-02-2014, 01:28 PM
jon6.0
jon6.0's Avatar
If you do a radiator and you have a centri blower, just get the shorter radiator so you can fit a 4" inlet tube like the Dallas Performance inlet. Unless you car is running hot in the summer during in town driving, I really wouldn't worry about the radiator. Mine is since I'm in Phoenix, so that's on my list of upgrades before summer hits again.
Old 02-02-2014, 01:29 PM
jon6.0
jon6.0's Avatar
As for the crank pulley, I had my buddy's shop do it. So it was real easy for me, lol.
Old 02-02-2014, 02:02 PM
edge04
edge04's Avatar
I do plan on some road course racing but think I'll wait and see what temps I run. Going to switch to a vented hood because I like the look so that will help.
I have the tools to pull the crank, just looks like a PIA because of the space.
Old 02-02-2014, 02:22 PM
jon6.0
jon6.0's Avatar
If you have access to a lift it makes it easier. Doing it on your back under jack stands would suck I think.
Old 02-02-2014, 03:01 PM
edge04
edge04's Avatar
Yep have a lift. Going with 10 rib 10%overdrive IW crank pulley with 4 up top. Will start there. Thanks
To Looks like its 8 or 10 rib time
Quick Reply: Looks like its 8 or 10 rib time
