Overseas build: 1004rwhp C6 with 4L80E and F2 Procharged
#43
Supporting Vendor
looks sick bro! I ditched my DP Cog setup and will be putting it for sale soon due to not being able to keep belts and went with a 10rib setup. maybe it was just my car and install (even though triple checked alignment) but hopefully yours will be better. car looks great and very nice build indeed! hope to see some 8sec passes real soon! good luck!!
#46
#47
Mo BTW weather was finally half way decent last Saturday...tossed in some C16 and ripped the streets with 26.5PSI!!!!
INSANE..60-130 ~3.7
CANNOT WAIT TO SEE UR VIDS!
#50
It seems that there's still no solution for NW 102mm throttle body with high hp cars, although some say you can fix it with sct. Anyone willing to share?
#52
[QUOTE=WHITE_SHARK;1586470639]Update....
NW102mm TB had been replaced due to REP and p1516 dtc code,,, went back to factory 90mm without issues so far...
I too have had this issue
#55
Were you using the Speed Control brand belts? I had nothing but problems with those belts. I've found some belts that work way better in the HTD tooth profile. Aside from that, I've been working on a new design with an entirely new belt tooth profile. I have the cog pulley designs completed and built. They're interchangeable with ease utilizing a quick-hub design as opposed to the IW design that only offers one tooth profile and 2 sizes. The strongest belt that Gates offers in the 8m HTD tooth profile is only capable of holding 240hp, best case scenario and that's steady state, not counting shock loads. The custom poly chain is capable of holding over 600hp of load and better withstanding shock loads.
#56
well how many runs did you do on the street??? mine was also fine for the first probably 7-8 pulls but then it breaks. but I am glad your is working properly! maybe its just my luck or installation or something else...
#57
[QUOTE=NICK YOSKIN;1586526776]im having that same issue on my zr1 right now with a ported ls7, pd blower is sucking it shut lol
#58
Nick has replied to me by saying (2 weeks back), "If it is happening under WOT with boost there isn't much to do. The issue is in the GM electronics.
I do have a new one with a different motor in it doing well in testing at the moment."
