Rear end gear ratios
What rear end gear ratios are you supercharged c6z guys running. I have stock ratio, I'm at 800rwhp and running 143mph in the quarter thought it would be higher.
99.9 are going to be running stock since no one makes anything else. You can adjust it slightly by running a taller or shorter tire. The other option is to switch to a base diff then that opens a few options up but most z06 guys aren't going that route, especially with high power.
Bad 1.9-2.0. Not getting any runs cause I keep getting banned before I get the launch down. Need to go to a track rental. 60ft shouldn't affect mph on top end by much.
