Heartbeat Cutaway
Former Vendor
Heartbeat Cutaway
Hey guys - lots of people have been asking me for more detail on the internals of Heartbeat, especially when it comes to what makes it different from other kits on the market.
Our R&D team created this cutaway drawing that shows the insides of Heartbeat, and explains the unique features. Check out the inlet and input shaft design in particular, and how our engineering team managed to maximize the airflow going into the rotors (superchargers hate restrictions on the inlet side). You can also see the intercoolers - we went with the most advanced intercoolers we could find, and the same technology from the same company is used in F1 heat exchangers. The cool thing about them is not just their efficiency, but how well they flow and minimize pressure drop going into the ports.
Enjoy. A little light reading for a Friday afternoon for those of you, like me, that get excited about the technical detail:
Matt, thanks for posting the above diagram. Looks really cool! Quick question, what's the dimensions of the chargecooler bricks used? They look a lot bigger than say the Eforce ones but I can't seem to get exact dimenssions.
Also you mention f1 heat exchange technology. Can you shed any light on what is different between that and say a conventional change cooler core?
Finally, from the testing your teams (and external 3rd parties) have carried out, will this unit support as much power as the LS9 supercharger assembly?
Former Vendor
- they are extruded tube (not rolled) with thickened leading edges profiled to reduce restriction
- thin walled on the sides, dimpled for coolant turbulence, webbed for strength
- the fins are louvered for maximum cooling with minimal pressure drop, surface-fused (not edge-fused) for maximum transfer, & full-length (minimal end bypass)
- dual-pass with double-sealed caps
I'll upload a more detailed explanation of the above shortly - we just finished a video interview with our chief designer.
We're convinced that Heartbeat will outperform an LS9, even a ported one. Proof is in the works - stay tuned!
Former Vendor
What would you expect from a stock LS3 Grand Sport 6 manual with headers and a tune with the stock pulley?
Former Vendor
Are the headers already on the car, and if so, do you know what your car is putting to the wheels with the headers? The headers should add roughly the same supercharged as it does naturally aspirated, provided you have a good tune.
I think it's taking eaton a while to get the rotor packs out. I'm sure magnuson want to get hold of it as the market is pretty massive and hopefully the casting / tooling cost won't be that much. Obviously there is still a little r&d work required but hopefully kits will be out soon.
NCM Lifetime Member
NCM Lifetime Member
I've got the heartbeat installed with pfadt headers, stock pulley, and a tune, and am putting out about 520hp to the rear wheels but have an automatic, not a manual...have run it now for about 3k miles including a round trip from Texas to Bowling Green, runs smooth as can be...
