issues with McLeod RXT / stock slave cylinder clearance - .0625 preload
So I've lost 2 stock slave cylinders in the past ~2k miles. Both ~1k miles each after I completed my build using a McLeod RXT clutch. I have the RXT, aluminum flywheel, stock crank, stock bell housing and stock torque tube. From everything I've read and been told by McLeod this should work (and is working for many others).
While I replace this slave cyl, I took some measurements and found that the slave cylinder appears to be preloaded against the clutch pressure plate.
Melt down pic:
Measurement instructions:
My 'A' - 3.1875"
My 'B' - 3.25" (compressed)
A - B = -.0625
This measurement should not be negative (preload). The recommended distance is .125" to .200"
Has anyone else had issues like this with either a McLeod clutch or other?
Is it ok to try a temporary fix of shimming the torque tube using .1875" to .2625" washers to get my clearance? Or will this weaken the connection between the torque tube and bell housing since the full surface area is not sitting flush?
Melt down pic:
My 'A' - 3.1875"
A - B = -.0625
You could try a zr1 slave and shim it up. They are much shorter. I have a brand new one at shop if you need it. Strait from gm. I'll probably never use it.
On my 5th gen camaro when I did a twin disk I had first used washers between bell housing and block. To get desired height.
But eventually had a motor plate made with the ears cut off. Then had it milled locally to my required thickness.
Weird. It's like your car has some sort of wrong build tolerance. What about maching some off the back side of the slave so it sits farther down? If a ZR1 slave won't work like previously mentioned.
Like this:
I picked up 10 washers (2 for each torque tube/bell housing bolt to make up 5mm). I'm concerned about how the load will be spread over those 5 circles now though vs. spread evenly over the mating surface.
There's not enough material there to machine down 5mm
My options will either be to pick up the LS9 slave and shim it (waiting to see how much based on the measurements above).
Or buy an aftermarket slave cylinder to the specifications of my measurements.
3.5 and 2.6 area from what I can find looking it up on google. Someone else had posted Thier measurements. I'd have to grab it from shop to get my own.
So a 3/8 spacer would put it right where you need to be?
I wouldn't do washers on the torque tube. I would have a machine shop make you single spacers of an exact thickness once you for sure know what you need. Best would be a one piece spacer that would go between the bell housing and torque tube. If it's the McLeod, have you tried contacting them to see if the unit they sent you is out of tolerance somewhere? Maybe see if they will send you the print with all the dimensions for everything. Flywheel too thick maybe? I'm just spit balling here. I'm now a little worried as I have an RXT with a steel flywheel waiting to go on when my LS7 clutch gives up the ghost.
I need it to be .1875" to .2625" shorter.
So my final compressed height (with shim) on the ls9 slave cylinder would need to be 3.25" to 3.175".
Depending on the exact compressed height of the ls9 slave I can determine the shim size I need.
I'll definitely be contacting McLeod since this has been very tiring and cost me 2 slave cylinders.
The next repair will use an ls9 with the appropriate shim, I'd rather work it from that angle.
Washers worked fine for a long time in my camaro. I think I had 3 per bolt? Shooting for 3/16s of an inch. And that was a 4100lb car on drag radials with a 560rwhp motor and a bunch of nitrous.
Supporting Vendor
Be careful using washers as they are always different thickness. With the Quicktime bellhousing, You can measure with it all bolted up. There is a hole in the bottom of the housing. Maybe you can try one washer to help with more clearance. I would of thought with that much preload you would of burnt up the clutch disc. Hopefully you get it all figured out, It's a pain to keep removing the torque tube assy.
The extra preload on my car caused my clutch to not hold. That's what first made me aware of an issue.
It is weird that the clutch grabs fine preloaded like this, that's one of the things I'll be asking McLeod about, I want to make sure my clutch life hasn't been shortened.
Of course the one measurement I didn't grab was from flywheel surface to fingers. McLeod says that this should be 2.1".
I guess when it's apart next I'll check that measurement.
They didn't have any ideas on why I was having this issue, but told me that if I shipped it to them, they could look at it and get back to me in ~5 days.
Hopefully the ~1.6mm of preload gives me another ~1,000 miles and it'll be a winter project to see whats up and take the corrective action w/ a LS9 slave + shim.
So this is a picture of an LS9 vs. LS3/LS7 slave cylinder. No measurements unfortunately, but based on my picture above and the only difference appearing to be that cast spacer, I'd guess it's ~1" shorter.
This would place the compressed height of the LS9 at ~2.4375". I need it to be ~3.25" to 3.175", so I would need a .8125" to .7375" shim.
That's huge and there's no way it would work.
I guess that blows the shimmed LS9 idea away.
http://www.vetteweb.com/tech/vemp_10.../photo_16.html
Looks like Quarter Master tri-lite 2 is going to be the ticket...
They have 3 sizes (waiting to confirm they're measured base to bearing surface using the OEM style flat bearing). The sizes are 3.150, 3.200, and 3.300.
So I should be able to order their 3.200 size and be set. It comes with the total assembly + bleed line + line to connect to the oem master cylinder quick connect.
