C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Next Step? Seeking more HP
Old 08-03-2013, 12:07 PM
dprescott878
dprescott878's Avatar
Default Next Step? Seeking more HP
About a year ago I purchased my 2006 M6 Z51, the previous owner had installed a LS3 top end along with mild comp cam and stroker kit (413 ci) with supporting mods (10.9 compression) and car put down around 480 to the wheels when I got it.
I was looking for more power but was hesitant to go FI due the build being fairly high compression. I decided to go ahead with an ECS 1500 kit along with DeWitts Radiator, Mantic 9000, and headers. That resulted in roughly 650 rwhp, but I was running out of fuel up top (w/BAP only).
I then added an Alky Control Meth Kit (single nozzle) and ECS stage 1 fuel system which resulted in 750/680 to the wheels. I have become used to the current power level and am looking for the next 50+ hp. Any suggestions on what would be the most cost- effective way to add more power? Also would I be pushing it too far due to the fact that the original build was set up for NA (10.9 compression)? Any info will be appreciated.
Old 08-03-2013, 12:11 PM
jon6.0
jon6.0's Avatar
I would do a fuel system and smaller pulley. E85 and larger injectors if you can get E85. What is your current pulley size and boost level? Even if you can't get E85 I would pulley down and do a dual nozzle meth setup with whatever ECS recommends for that power level.
Old 08-03-2013, 12:20 PM
dprescott878
It is the stock size pulley that came with the ECS kit (3.25" I think). I am currently seeing about 12 psi max. I do have the ECS stage one fuel system- I think I can order the extra parts to upgrade to the Stage 2. I am trying to stay away from E85. Will it be safe running a smaller pulley than the 3.25"? I am fairly high compression (10.9:1) and have read that most cars built for high boost are usually running lower compression.
Old 08-03-2013, 12:38 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Don't need to swap pulley, just pull the restictor plate and add more meth.
Old 08-03-2013, 12:51 PM
jon6.0
jon6.0's Avatar
12 psi sounds like the plate is already pulled. Dual nozzle meth for sure. Is your cam tailored for a centri blower? You could do a custom cam that is bit more aggressive since you have a stroker.
Old 08-03-2013, 12:55 PM
Unreal
Unreal's Avatar
If the pulley isn't pulled. Single nozzle should be good for 800rwhp, may not need a second yet.
I would call ECS and just see what you need to get another 50.
Old 08-03-2013, 04:57 PM
dprescott878
Thanks for the input, I will give ECS a call next week and see what they suggest.
Old 08-03-2013, 04:59 PM
Silver Bullet C6
Silver Bullet C6's Avatar
St. Jude Donor '10-'11-'12
I agree with you and would be concerned about hitting 800 whp with 10.9:1 CR. What cylinder heads do you have and are they ported?
Old 08-03-2013, 06:30 PM
dprescott878
Previous owner said CNC Ported LS3 heads.
Old 08-03-2013, 07:58 PM
dprescott878
Cam specs: 230/236 .591 .602 lift 114 lsa.
Old 08-03-2013, 09:48 PM
jon6.0
jon6.0's Avatar
You can definitely get a more aggressive cam with the cubes you have and still have good driveability.
To Next Step? Seeking more HP
Quick Reply: Next Step? Seeking more HP
