C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
need injector identification please
Old 07-30-2013, 10:08 PM
LSOHOLIC
LSOHOLIC's Avatar
Default need injector identification please
Can someone identify this injector ?? I thought it was an LS7, but Im second guessing it now. None of the numbers on the injector correlate to oem part number.
http://imageshack.us/a/img825/6420/uzri.jpg
http://imageshack.us/a/img834/4079/nov0.jpg
Oh, and sorry the dang pics are so large....lol.
Old 07-30-2013, 10:16 PM
gotjuice?
Support Corvetteforum!
gotjuice?'s Avatar
St. Jude Donor '13
It looks like a medium length. That would be LS2 design. Google the number on the injector.
Old 07-30-2013, 10:24 PM
LSOHOLIC
LSOHOLIC's Avatar
Its 2" long....from my digging that would be either a LS7 or the LS3. And the dang numbers on the body get zero hits on the "net".
LS2=65.2mm=2.5625"
LS7=53mm=2.12"
Also the LS2 bodys have a metal band in the middle of the body, these do not...
Here is a quick reference pic
http://forums.corvetteforum.com/c5-p...tschwerks.html
Old 08-05-2013, 05:11 PM
0Xplosive Performance
Former Vendor
Xplosive Performance's Avatar
St. Jude Donor '13
take a look at the black body you will need a magnifing glass
just below the connector on the opposite of the connector you will see some numbers look for a 0280158051 if its that number its a Bosch 43lb injector @ 1 Bar LS3/LS7 that injector is capable of flowing 65Lbs @ 4 Bar. the 10 digit number is the bosch part number google that if different
Old 08-10-2013, 06:00 PM
LSOHOLIC
LSOHOLIC's Avatar
That is exactly what I thought but.....there are zero GM numbers on the body. The obvious reason they are not LS7/3's is because they hit 120% dc @ 513rwhp well under max rpm....... We put a guage on the rail, pump didnt waiver any....solid 58lbs. Also, we were commanding 14.68÷1.18 w/NGK wideband.
I bought these injectors off tech and were sold to me as LS3's.....guess you live and get burned, I mean learn...lol. So I decided to tossed four of them on a injector flow bench. LMAO, barely made 34lbs....
Lesson.....Chinese knockoff don't flow like OEM Bosch injectors !!!
To need injector identification please
Quick Reply: need injector identification please
