2007 C6 LS2 MN6 with New blower Cam
I just had a new blower cam with specs: 227 INT ; 289 EXH DUR@.050 lift .618 INT ; .623 EXH & lobe separation of 115. I just added 1 7/8" with #3" with Hi-Flo Cats from Kooks Headers and ZR1 Bi-Mode mufflers.
I was told that this cam is easy on the valve springs. I also had roller bearing trunnions for the stock rocker arms and heavy-duty push rods added.
My next plan is to go with A&A SC. This is not designed to race but have bragging rights about HP and drivability. I also take long trips to Maine and NY. I also enjoy mountain roads for spirited driving. My goal is to have 650RWHP and 600 + RWTQ.
Forum Members, do you think this is possible for this car? My last dyno w/o blower was 437 RWHP and 397 RWTQ. Will I come up short?
Thanks in advance for your help!
Depending on what blower you want si or t trim. You can reach 650 with that cam no problem. Which ever you choose (t trim) get a 3.6 pulley and your tunner should make good power with it. 650 is a very nice and controllable power for the street. I have alot of fun with 652
I just made 780rwhp and 645tq on an 05 LS2 MN6 using an ECS 1500 kit with their small blower cam (they don't give out the specs) and meth. The car cruises great and is a monster when I want it to be. I could have made 650hp with this setup even without a cam.
Assuming the A&A is similar in performance then you should be okay.
Question for OP. I notice that you said your cam is easy on the valve springs. Does that mean that you didn't have matched springs installed with that cam? Hope not.
Hp numbers would have to be after cam install.....not going to see 437rwhp on a bolton ls2 only
Yes I did upgrade springs with the swap. I don't remember the brand name.
I am looking forward to the A&A supercharger to see what my final numbers will be. I need to save for the unit first or sell some things I guess.
