boost gauges wiring question
Ok so I got my glowshift boost and fuel gauges in. I started on the wiring but stoped due to me now having a drill to drill through the fire wall. Anyway....
I need a constant power source, switched and a headlight source for my power wires. I know the trunk button (brown wire)-(switched?) is one and one of the yellow wires under the steering column. I dont know where a headlight source would be best to tie into.
So if anyone can help to let me know what and which ones would be best to tie into tha would be huge, thanks !
I had the same issue. I ended up pulling a wire from the main fuse box in the engine compartment through the large grommet under the battery on the fire wall over to the gauge. I put a jumper on the low beam head light fuse. I used 3m 5200 to seal the hole I put in the grommet. Good luck
ok so I hooked them all up and after a short ride noticed my boost gauge was reading -8 while driving and -13 while idle. When the car is off it goes back to 0......Then all of a sudden I assume I got a vaccum leak as my check engine light came on and it was running a bit rough. The vaccum line it came with is clear and cheap and I will be replacing that soon.
Any ideas or hints?
Any ideas or hints?
