Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
A&A Superchargers
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-21-2013, 12:54 AM   #1
Jeffro_510
9sec car, 10sec driver
Support Corvetteforum!
Jeffro_510's Avatar
Jeffro_510
Default Pulley swapping, need help with belt size?
I am swapping my crank pulley out, so i have to swap my blower pulley out to keep from over rotating.
Currently, the car has an 8 rib 3.125 blower, 8 rib 7.5 crank pulley setup.
I am swapping the crank to an 8 rib 8" IW pulley, and the blower will get an 8 rib 3.5 pulley.
I have the ECS bracketry, and a Paxton Novi2200SL head unit. The car is a 2005 LS2 Powered Vette.
Anyone else run the same setup and can get me a part number, or a length or some kind of help?
thanks in advance
Jeffro_510 is offline   Reply With Quote
Old 06-22-2013, 02:28 PM   #2
mourat
CF Senior Member
mourat's Avatar
mourat
Maybe this will help:
http://www.vortechsuperchargers.com/page.php?id=33511
Basically see what Impeller speed was with your old setup, and new setup that should give you a good approximation of how big the belt needs to be.
mourat is offline   Reply With Quote
Old 06-23-2013, 01:25 AM   #3
Jeffro_510
Jeffro_510's Avatar
Jeffro_510
There is no info there on a belt length.
I have already figured out my blower rotation, and know i can run a 3.4 to 3.5 pulley. But I have no clue as to what belt i need to run one of those pullies.
i also don't know if ECS belt configuration/length is different than others either.
Old 06-23-2013, 09:45 AM   #4
95vettski
CF Senior Member
95vettski's Avatar
I would call ECS and ask them...I'm sure they have tried that combo.
__________________
04 ZO6 Black/Black ● Champion Motors 402ci
ECS Paxton Novi ● 10.13 @ 149 1.84 60'
909 rwhp 812 rwtq
http://www.youtube.com/watch?v=7QpWNgbBNRs
95vettski is offline   Reply With Quote
Old 06-23-2013, 10:49 AM   #5
Slo-Poc
CF Senior Member
Slo-Poc's Avatar
How much boost are you seeing with that setup with the 2200sl
Slo-Poc is offline   Reply With Quote
Old 06-23-2013, 01:46 PM   #6
Jeffro_510
Jeffro_510's Avatar
Jeffro_510
With the 3.125/7.5 setup, i was seeing about 15psi, it may have been more, i ended up having a head gasket issue, where boost was getting into the cooling system
Old 06-23-2013, 02:12 PM   #7
Jeffro_510
Jeffro_510's Avatar
Jeffro_510
This was on stock cube ls2, stock 243's, and stock ls2 intake. Very restricting top end. Car did make 745 to the wheel though.
With my new heads, i expect to see less boost, but make more power.
Reload this Page Pulley swapping, need help with belt size?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
