N/A and E85, What fuel pump?
Im planning to build either a stock cube ls2 or a 402 and run e85, My power goals are mid 500's at the most so I need to know what pump to run. Most external kits or dual pumps will be major overkill.
I was thinking about running this pump and a boost-a-pump. What do you guys think?
http://www.lingenfelter.com/mm5/merc...Store_Code=LPE
Or will this pump fit in the stock c6 fuel bucket and i could just run this pump?
Not sure. I'll call the shop tomorrow and ask. This is him: http://forums.corvetteforum.com/c6-z...p-for-e85.html
I have a 450 in mine too. slight modification. Here is what another member did which is the only problem with the walbro 450
"" Ended up cutting a hole in the side of the bucket for the sock, since it doesnt come with a venturi to keep the bucket full. ""
I have thousands of miles on mine without a problem. injectors, I would recommend getting at least 80# if it was me since its the same price. it doesn't hurt having a bigger injector incase you need to upgrade later.
Yea i know what you mean, I am hoping to be around 13-14 to 1 compression with my build and i will also be spraying it with a 200-250 shot.
Or you can do what I did:
http://forums.corvetteforum.com/c6-f...el-system.html
E85 pump solely feeds the engine and wastes no output flow as a transfer pump or venturi. The stock pump sits inside same bucket but takes fuel from outside the bucket and all it does is fill the stock bucket by way of its own FPR, by the small venturi oem, and also transfers fuel from passenger side.
On top of that I added a boost a pump
No probs, glad you like it and called it bad a$$
The vacuum / boost referenced FPR cleans up your idle sooo much thanks to lower fuel pressures down low, you can get your Siemens 60lb shorties which are 80lb at 4 bar, to pulse at around 1.5+ at idle instead of 0.8 and less
