C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
10K Budget
Old 04-23-2013, 08:48 PM
Shostopper
Shostopper's Avatar
Default 10K Budget
is 800-850Hp attainable on a 10k budget for a stock LS3 motor?
Old 04-23-2013, 08:53 PM
Z06-TT
Z06-TT's Avatar
I have a hell of a deal for you.
Message me your email.
Old 04-23-2013, 09:13 PM
jon6.0
jon6.0's Avatar
I would not go 800+ rwhp with a stock motor. 700-750rwhp would be completely do-able though. With a good tuner you should be fine. Talk to ECS or A&A. I would get ECS if buying new or if you get a deal on a used kit, get either. You will need a clutch and fuel system also for that power level. If you can do your own install it will be close. Paying somebody to install it, budget for $15k if buying all new stuff. I got a deal on a used T-trim A&A with 103# injectors and external add on fuel system for $4500. Add in the install, new tires, and tuning and I was at $8500 total. I'm only at 578rwhp and need to do a clutch before I can pulley down. That will be another $2500 in parts and labor.
Old 04-23-2013, 09:14 PM
Le Mans Z06
Le Mans Z06's Avatar
Without used parts I don't see how...
Old 04-23-2013, 09:17 PM
gotjuice?
Support Corvetteforum!
gotjuice?'s Avatar
St. Jude Donor '13
Cheap, Fast, Reliable----you can only pick two.
Old 04-23-2013, 09:25 PM
Shostopper
Shostopper's Avatar
ty for the replys I can go over 10k but would like to stick as close to it as possible and the car is an A6 and I will be using new parts not used.
Old 04-23-2013, 09:29 PM
jon6.0
jon6.0's Avatar
No way in heck is that possible with an A6. You would need to completely build that trans and I think ECS only builds them in house. Half your budget would be gone with the A6 build. Settle for 600-650rwhp and I say it's possible with $10k. You will still be playing Russian Roulette with your trans though. Make sure you do a real good trans cooler.
Old 04-23-2013, 09:34 PM
Le Mans Z06
For that you can do a blower kit, headers, and meth. You could probably see 650rwhp or so with that, but going above that can be risky without building your trans or adding a fuel system which is taking you above 10k for sure...
Old 04-23-2013, 09:38 PM
madmax4499
madmax4499's Avatar
why do you want so much? 600 rwhp Is insane and tons of fun.
Old 04-23-2013, 09:40 PM
jon6.0
jon6.0's Avatar
I completely forgot about headers. If you can get E85, you don't need meth. Don't forget to add a wideband. I used the AEM failsafe wideband, which also shows boost.
Old 04-23-2013, 09:44 PM
jon6.0
jon6.0's Avatar
I have 578rwp and 511tq at 7psi with a stock cam LS3 and it's deceptively fast. Very smooth and before you know it you are at 120mph on the freeway on-ramp.
An ECS blower will make more torque than me due to their restrictor plate use on the inlet. They use a smaller pulley, but the restrictor limits peak boost. Gives you a fat torque curve compared to a centri car with a larger pulley and no restrictor to get the same peak boost.
Old 04-23-2013, 09:49 PM
Shostopper
Shostopper's Avatar
Why not
Old 04-23-2013, 10:08 PM
BoosTTed C6
BoosTTed C6's Avatar
Base ECS kit installed $ 7800
ECS meth kit installed $ 1000
Headers plus install $ 2300
Used Z06 mufflers $ 500
Fuel system installed $ 1250 (You can do boost a pump but I wouldn't and didn't).
I am willing to guess 675 whp (easy) thru auto.
I have the above on an LS2, made 720/643 through manual transmission and 4.10s. 720 whp is plenty fast. With traction, you are in liter bike territory.
Old 04-23-2013, 10:16 PM
Shostopper
Shostopper's Avatar
I'll have to get a fuel system the closest E85 station is 30plus mins away
Old 04-23-2013, 10:21 PM
jon6.0
jon6.0's Avatar
Are you doing the install yourself?
Old 04-23-2013, 10:33 PM
londonk
londonk's Avatar
no way ...20 k with an auto
Old 04-23-2013, 10:39 PM
kbobk
kbobk's Avatar
These price are on the low side to include quality install and don't forget a tune. The little things will nickle and dime you to death. You should consider a radiator, injectors, intake, TB, and I recall a meth kit costs more than $1K installed.... etc. You should budget $15K+ to do it right. It cost me more than that to get 678RWHP through a manual. That was on top of the cam, gears, headers (483RWHP) done years ago when it was NA. You got to pay to play!
To 10K Budget
Old 04-23-2013, 10:42 PM
Shostopper
Shostopper's Avatar
No if I go SC I will send it to ECS and if I go TT I will probably go to UPPCOS or try and find a APS kit if one is still around
Old 04-23-2013, 10:57 PM
madmax4499
madmax4499's Avatar
Make a budget; then double it!!!
I hear you on the "why not" I have both a 600rwhp and a 1000+rwhp car. "both twin turbo cars" the big boy is parked most of the time. Just not that fun to drive on the street. Have you driven a car with this much HP. unless you can budget for that A6 build stick with 580-630rwhp, you will be glad you did. + you can always turn it up later as you build supporting mods. Good luck Brother!
oh, dont buy Z06 mufflers.
Old 04-23-2013, 11:06 PM
jon6.0
jon6.0's Avatar
I have a Z06 axleback. I bought the Pfadt headers for a Z06 and didn't want to use my 2.5" stock axleback. I'm running the flappers open all the time. Small amount of resonance from 1400-1700rpm. I just shift around it for now. I've got a friend I will get the vacuum canister from when I get tired of the resonance.
I have a friend that has a 1000/1000 twin turbo C6. He runs around in low boost and its still ridiculous. Around 750/750 on low.
Quick Reply: 10K Budget
