Anyone blow rear main seal after s/c install
I have a 09 6sp c6 with a&a kit with 34k on motor s/c been on for about 500 miles I only been hard on the car like three times now I see couple of oil drops in the garage care the car back to shop that did install and they said rear main seal is bad so they said might as well do clutch sense you got that apart and catch can what you guys think dont want this car to be like my c5 always down if it comes to it I will take s/c off
A lot of people have. If you don't have enough venting it will go out easy.
No issues with mine. I was really careful with the install of the rear cover. I repaired a ZR1 that was driven 300 miles after upgrades and it ate up a rear main seal. Make sure you check the cover and don't just replace the seal.
I'm gone for TI this weekend, but maybe next week? Just keep it out of boost for the time being.
This is way cool . It's awesome of you to share your knowledge and offer to help.
Thanks Ill take you up on that I sent you a pm
did you do the catch can after you made the thread about it?
send me a pm if you want work done, there is a much better option closer to lees summit than the shop you used.
