Round 1.2 DIY: Finally 1k rwhp??
04-20-2014, 02:36 PM
Quote:
Originally Posted by
Tuomas FIN
Asking here also, tried to get first start yesterday, everything else OK except starting.
Crank relay do not click, power ok, relay ok, fuses ok, just start signal is lost and car do not start.
Any ideas, wires seems to be ok, new ignition switch and everything else works.
Thanks in advance!!
Ajonesto?
04-20-2014, 04:05 PM
Pekka_Perkeles
Ajonesto?
Nope, Tikt adjustable clutch cylinder didn't push the switch on the bottom.
Was not adjusted yet so problem solved and first smoke taken!!
04-20-2014, 04:09 PM
Vid:
04-20-2014, 05:00 PM
Another, bit funny
04-23-2014, 12:46 AM
Some small details.. Tomorrow axle alignment
04-23-2014, 08:45 PM
Done. Next break in and then dyno.
05-21-2014, 05:47 AM
edit
05-21-2014, 09:33 AM
edit
05-23-2014, 06:33 AM
Didn't I tell you to put Supra engine in it! :-)
Good work from double-ÖÖ, btw.
