Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
A&A Superchargers
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-09-2013, 12:40 PM   #1
Icevettez06
CF Senior Member
Icevettez06's Avatar
Send a message via AIM to Icevettez06 Send a message via Skype™ to Icevettez06
Default Are some of you running Turbo using Brake Booster?
I´m thinking about adding brake booster. Brake has kind of slow response after VOT. What are you using for this those of you which have done some mod on the brake?
Icevettez06 is offline   Reply With Quote
Old 02-09-2013, 08:46 PM   #2
NICK YOSKIN
CF Senior Member
St. Jude Donor '08
NICK YOSKIN's Avatar
Quote:
Originally Posted by Icevettez06 View Post
I´m thinking about adding brake booster. Brake has kind of slow response after VOD. What are you using for this those of you which have done some mod on the brake?
Are you having power assistance issues with brakes? What kpa does your car idle?
NICK YOSKIN is offline   Reply With Quote
Old 02-10-2013, 04:57 AM   #3
Icevettez06
CF Senior Member
Quote:
KPA is 45 at idle. Brake work fine in normal driving. This is only after let’s say I hit it hard at the throttle 2 or 3 gear and then I hit the brake really hard then the brake do not kick in as hard as they should do or much worse than they did on me older 2002 Z06. KPA after run drops to 17 and it takes 2 sek to get back to 45. Brakes work fine at the track but I don´t hit them hard after the run. But at the street when you need to be able to stop quickly after smoking the tire you need them to kick in really fast.
http://scandc.com/new/node/712
Old 02-10-2013, 11:54 AM   #4
07MontRedcp
CF Senior Member
Support Corvetteforum!
07MontRedcp's Avatar
I'm wondering if it has something to do with your BOV having a little lag and you are hitting the brakes before it has recovered from venting the boost.
BJK
__________________
APS TT 630 rwhp/654 rwtq @ 9 psi
'07 Z51, TR6060 conversion w/Z06 ratios. DTE Stage 4 Quaife Diff w/brace (3.73). Z06 Brakes, mild turbo cam & dual springs (222/222, LSA 115, .581/.581), LS9R clutch, LG GT2 Coilovers, Autometer Cobalt Fuel gauage, Progressive Alky Controller, and e-Boost2 Controller. PFADT poly bushing for control arms and Sports sway bars. MGW shifter. 3" B&B Fusion. RSI Stage 1.5 fuel system. RX dual valve catch can.
07MontRedcp is online now   Reply With Quote
Old 02-11-2013, 04:25 AM   #5
Icevettez06
CF Senior Member
Quote:
BJK
I pretty sure that this is boost related and it have to do with recover time from going from boost to no boost. I would have thought more people have same issue.
Old 02-11-2013, 06:50 AM   #6
narfdanarf
CF Senior Member
narfdanarf's Avatar
Would you be willing to make a little one line diagram and post it how and where you have each vacuum line hooked up? Most importantly the brake booster and any lines tapped off of it.
narfdanarf is offline   Reply With Quote
Old 02-11-2013, 08:02 AM   #7
Icevettez06
CF Senior Member
Quote:
I believe that all is stock except APS c6 turbo kit. I will take closer look at the Brake booster lines to night.
Old 02-11-2013, 08:14 AM   #8
RoadRebel
CF Senior Member
RoadRebel's Avatar
replace the brake booster check valve with a new OEM GM and try it again.
RoadRebel is offline   Reply With Quote
Old 02-11-2013, 10:25 AM   #9
07MontRedcp
CF Senior Member
Exactly, and the BOV is what does that. When you lift on the throttle, the BOV senses that and opens to release the boost that has built up in the intake manifold and all vacuum lines that are not protected by a one way check valve. As for me, I have never slammed on the brakes in that manner.
BJK
__________________
Old 02-12-2013, 09:54 AM   #10
Icevettez06
CF Senior Member
All seams stock except there is one tube from manifold to the BOV on both sides.
BJK
I think that is the case that this is the time it take for the BOV relies the build psi. I did cheek the one way valve in the brake air drum and it seems fine. So what is the best way to fix this? New BOV?, Brake booster or drive slower and live with this!!
Old 02-12-2013, 11:49 AM   #11
07MontRedcp
CF Senior Member
Just a thought here. I checked your profile and your quarter mile numbers. Could it be that you need to upgrade to bigger BOVs to vent the boost faster?
BJK
Old 02-13-2013, 06:59 AM   #12
Icevettez06
CF Senior Member
BJK
That is interesting. I´m still using stock BOV and bigger turbo. I think APS C6 BOV is not the same as APS ZO6 kit have. Any other turbo experts out there have opinion on this?
Old 02-13-2013, 11:35 AM   #13
07MontRedcp
CF Senior Member
Here are pictures of the C6 APS waste gate (Blue Hose) and the Z06 APS waste gate (Black hose). Notice the difference in size.
BJK
Old 02-14-2013, 10:49 AM   #14
Icevettez06
CF Senior Member
BJK
I will look in to this. Thank you for your effort and input.
Reload this Page Are some of you running Turbo using Brake Booster?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
