C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Anyone here daily drives the Gt9 cam?
Old 12-30-2012, 02:09 PM
94 guy
94 guy's Avatar
Default Anyone here daily drives the Gt9 cam?
if so have you checked the rocker arm tips or valve tips? i here the lsk lobes should'nt be daily driven. Lingenfelter says you can daily drive them. thanks
Old 12-30-2012, 02:13 PM
lt1z
lt1z's Avatar
can and should are two different things
Old 01-01-2013, 06:01 PM
nullpointer
nullpointer's Avatar
I'm interested in hearing reasons why you can't (shouldn't) DD a lsk lobe. I have them on the intake side of my cam and have only "heard" they are more "race" than "street"...whatever that technically means.
Old 01-02-2013, 06:35 AM
helga203
helga203's Avatar
They also said that you can't run 8 rib set up on f2 pro charger at 30+psi. Well i have over 6k of pretty hard mile already with the same belt???????????????? :sma sh:: canadaflag::cana daflag:
Old 01-02-2013, 12:49 PM
94 guy
94 guy's Avatar
most so called cam guru's say you can't dd drive the lsk lobes. they say the gt9 will eat up the rocker and valve stem tips.
Old 01-02-2013, 12:51 PM
nullpointer
interesting info thanks, I'll make sure to test this in the summer. I'll be DDing mine with lsk intake lobes.
Old 01-02-2013, 02:59 PM
0Cunningham Motorsports
Former Vendor
Cunningham Motorsports's Avatar
with the right spring and install height, no issues.. if you plan to road race the car or do a lot of sustained high rpm, i suggest checking your springs once a year and possibly replacing them if need be. replacing springs on a c6 is quite easy anyway... cheap insurance
i forgot to mention earlier that we would highly recommend doing the solid stainless exhaust valves in the heads and checking the guides (replacing if need be) when doing the cam, we have simply seen too many fail on stock cammed cars. With the additional lift (including aggressive lobe ramp rate) and duration we feel it may aggravate and accelerate the issue.
Old 01-02-2013, 04:50 PM
94 guy
94 guy's Avatar
what's the right spring and install height?
Old 02-13-2013, 01:53 PM
94 guy
94 guy's Avatar
any more comments on daily driving the gt9? does anyone have a cam with the stealth idle and can make the same power as the gt9 on a softer lobe?
Old 02-13-2013, 06:29 PM
old motorhead
old motorhead's Avatar
Received 1,339 Likes on 947 Posts
A better option might be to use the GT11 specs (215/231) and just use LSL lobes instead of the LSK lobes. That would be a little easier on the valvetrain. One of the better shops on the Camaro5 board swears by the GT11 cam. He claims blown Camaros will get down the track faster with the GT11 vs the GT9. The GT9 will peak a little higher on the dyno, but the GT11 will have more power everywhere except at peak.
An even better option would be to use LXL lobes (they were bred specifically to be easy on the valve train) and do something like a 218/230 118lsa. Similar overlap to the GT9 and 11. Much more valvetrain friendly.
Old 02-13-2013, 06:33 PM
94 guy
94 guy's Avatar
i want something that makes more power than the ls9 that i have now. i know the gt9 is worth about 25rwhp more than the ls9
Old 02-13-2013, 07:11 PM
old motorhead
Bump it up to a 222/234 118 with LXL lobes. That will have decent manners and give a nice bump over the GT9. Idle will be rougher, but should behave well with a good tune.
Old 02-14-2013, 11:12 AM
94 guy
94 guy's Avatar
anyone else?
To Anyone here daily drives the Gt9 cam?
Quick Reply: Anyone here daily drives the Gt9 cam?
