C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Arp crank bolt with iw crank pulley?
Old 02-01-2013, 08:01 PM
jacked cobra
jacked cobra's Avatar
Default Arp crank bolt with iw crank pulley?
Can you use arp crank bolt with iw crank pulley?
Old 02-01-2013, 10:22 PM
turbotuner20v
turbotuner20v's Avatar
Yes, they sent one with my pulley
Old 02-01-2013, 11:10 PM
Arun@Dasilvamotorsports
Supporting Vendor
Arun@Dasilvamotorsports's Avatar
No, it's not long enough. And be careful with the bolt they send-it's not used to install the pulley and the torque is only 125 ft/lbs.
Old 02-01-2013, 11:47 PM
jacked cobra
Ok thanks. I noticed that the arp was a touch shorter. Didn't think it made a difference good thing i asked.
Old 02-01-2013, 11:48 PM
jacked cobra
Its for an LS7 if that makes any difference.
Old 02-02-2013, 12:37 AM
turbotuner20v
What did they send me then? I could have sworn it was arp with that torque spec. I've got the hawk balancer tool
Old 02-02-2013, 12:59 PM
Supporting Vendor
I just went an opened up a IW dampner-the bolt is a back anodized bolt by JDF grade 10.9 and it clearly says in the instructions to torque it to 130 ft/lbs.
Always use a dampner installation tool to install-like the hawk.
Maybe the LS7 does come with a ARP since the snout is shorter? I would use whatever IW provides and follow there instructions.
Old 02-02-2013, 01:07 PM
jacked cobra
I'll just call iw Monday and ask.
Old 02-05-2013, 03:49 AM
jacked cobra
Iw said if I can use the arp bolt.
Old 02-07-2013, 11:12 PM
Slowsome
Slowsome's Avatar
do you happen to know the length of the jdf bolt and the thread size they send? I got to get a new one...
Old 02-08-2013, 07:42 AM
Supporting Vendor
I will check today Brian.
Old 02-08-2013, 10:05 AM
Slowsome
Slowsome's Avatar
Ok, thanks a bunch Arun
Old 02-08-2013, 01:51 PM
Supporting Vendor
m16 5.5"
To Arp crank bolt with iw crank pulley?
Quick Reply: Arp crank bolt with iw crank pulley?
