Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
A&A Superchargers
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-07-2013, 03:26 PM   #1
revo1059
CF Senior Member
St. Jude Donor '11
Support Corvetteforum!
revo1059's Avatar
Default Upgrading crank pulley
When installing an A&A kit is it recommended (since it will all be apart)or is the stock one good enough?
revo1059 is offline   Reply With Quote
Old 01-07-2013, 04:28 PM   #2
Le Mans C6
CF Senior Member
Le Mans C6's Avatar
They fail even when stock, personally I would recommend it. I went 8 rib on mine that way when it came time to do a 8 rib setup it was already in place. You can still run a 6 rib off of a 8 rib setup (At least with the ECS kit, I would assume A&A is no different but maybe someone can confirm that)
Le Mans C6 is offline   Reply With Quote
Old 01-07-2013, 04:39 PM   #3
revo1059
CF Senior Member
St. Jude Donor '11
revo1059's Avatar
Any recommendations on one?
Old 01-07-2013, 04:47 PM   #4
Le Mans C6
CF Senior Member
Le Mans C6's Avatar
Quote:
ATI or Innovators West. I personally went with Innovators West.
Old 01-07-2013, 04:53 PM   #5
turbotuner20v
CF Senior Member
turbotuner20v's Avatar
I know it all adds up, but may as well do a cam then too if you're swapping the balancer.
turbotuner20v is online now   Reply With Quote
Old 01-07-2013, 06:27 PM   #6
revo1059
CF Senior Member
St. Jude Donor '11
revo1059's Avatar
Cam was previously done.
So is this what I should look into?
http://www.innovatorswest.com/842-LSX-Damper.html
Old 01-07-2013, 06:39 PM   #7
turbotuner20v
CF Senior Member
I'd go ahead and do the 10% overdrive while you're doing it. Just be aware that it will increase boost a bit. ColoradoSpeed had the best prices from what I found.
Old 01-07-2013, 08:17 PM   #8
Unreal
CF Senior Member
Unreal's Avatar
Send a message via AIM to Unreal
Get the 10% over up front, even if you have to pulley up on the blower it is worth it.
You should be able to get one for $500. IW is the way to go.
Unreal is offline   Reply With Quote
Old 01-07-2013, 08:50 PM   #9
revo1059
CF Senior Member
St. Jude Donor '11
revo1059's Avatar
So this would be it right?
http://www.coloradospeed.com/innovat...8-p-13817.html
Old 01-07-2013, 09:09 PM   #10
turbotuner20v
CF Senior Member
Yup
Old 01-07-2013, 09:14 PM   #11
revo1059
CF Senior Member
St. Jude Donor '11
revo1059's Avatar
Great, thanks.
Any other special bolts or pins or keys that I might need, or is it just a straight swap?
Old 01-07-2013, 09:18 PM   #12
turbotuner20v
CF Senior Member
Great, thanks.
You will need a crank pin kit unless you have an aftermarket crank with a key, also a new crank bolt
Old 01-07-2013, 09:18 PM   #13
Unreal
CF Senior Member
Unreal's Avatar
Straight swap besides needing to pin it just like the stock one. The stuff A&A sent will work.
I know you can get them cheaper than that though if you look around.
Old 01-07-2013, 11:37 PM   #14
revo1059
CF Senior Member
St. Jude Donor '11
revo1059's Avatar
Great info. Thanks
Can the A&A install be done with the car on jack stands? Also if I do the install myself can the car be driven as is to a tuner or do I have to trailer it?
Old 01-08-2013, 09:51 AM   #15
Unreal
CF Senior Member
Unreal's Avatar
Easy on jackstands.
You have a few options on that 2nd part. You could send your ECU for a base tune, find a local to flash in a file for you, tow it, or drive it there with the stock injectors and just swap injectors at the tuner. If you do the last one just don't get on it at all.
Old 01-11-2013, 09:29 PM   #16
Streetk14
CF Senior Member
Streetk14's Avatar
Quote:
Originally Posted by Unreal View Post
Easy on jackstands.
That's the hard part, but it's what I did. I drove close to 100 miles with the stock injectors, then swapped them and got it tuned. Just need to act like there's an egg on the gas pedal.
Streetk14 is offline   Reply With Quote
Old 01-21-2013, 12:37 PM   #17
revo1059
CF Senior Member
St. Jude Donor '11
revo1059's Avatar
Crap, the IW balancer sticks out too far for the A&A system (6 rib). I don't want to convert to an 8 rib system (just spending $ I'll never use up to it's potential), so this is what A&A recommends.
http://www.summitracing.com/parts/sum-c2501
Old 01-21-2013, 04:40 PM   #18
realcanuk
CF Senior Member
St. Jude Donor '13
realcanuk's Avatar
Send a message via Skype™ to realcanuk
I would go with ATI. I just ordered one myself.
realcanuk is offline   Reply With Quote
Old 01-21-2013, 09:50 PM   #19
revo1059
CF Senior Member
St. Jude Donor '11
revo1059's Avatar
Does the ATI fit with the 6 rib A&A system? Do you have a part #?
Old 01-21-2013, 10:08 PM   #20
Unreal
CF Senior Member
Unreal's Avatar
I don't think so. Matt@FPS told me the A&A kit is picky on crank pulleys.
Reload this Page Upgrading crank pulley
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
