1300-1400rwhp what injectors for 09 ZO6
Hello guys,
We're running ID1000 on TSP 454ci LSX Tall Deck with DKT 6766 Turbo..
The car now is around 16-17psi on straight 91octane pump gas at 1082rwhp 1097rwtq But it looks like we're at 80ish IDC maybe more How much more do you think these injectors will go ? I think it will max out at 1200-1250rwhp ?
We're planning to run the car around 25-28psi soon can we fit ID2000 on 09 C6 ZO6 without replacing anything?
Any other injecotrs out there for 1400+rwhp setup?
Thanks in advance.
Hussam
Thanks in advance.
Hussam
2000s will work on any PCM if your tuner is good. PM me if you want some help.
He will definitely be way up there in IDC on 1000s. It's OK though because the PCM has a built in 0.8ms reset time between injector shots.
we have ID2000's on 500 horse cars running just fine( getting ready for big builds.) but they are a great injector.
as soon as my customer says ok i want 800 horse ( or something close) i right there plan in the ID2000's. i am a HUGE fan of do it once.
I just bought Pro EFI myself so I'd say go for it if you can swing it. Once you get to a certain point you have to guess at it while tuning and that's no bueno. I've "heard" around 23-25lbs it starts to get hairy so I wouldn't risk it but it's up to you or your tuner.
Bosch will have there 2000cc fuel injectors out soon. They beauty with them is that there a REAL FUEL INJECTOR, not a CNG injector.
So you can thow any type of fuel at them without the worries of having them lock up.
Pricing will cheaper than the ID's as well.
I think Bosch will get to the point that they are used a lot. But ID will be what I use till that day comes.
