C6 Pillar Fuel/Boost Guage Pod Options
I'm sure this topic has been beaten to hell, but I can't seem to even find any pillar guages setup anywhere. I'm looking to spend less than $500, the only one I saw was the West Coast Customs pillar guage setup. What do you guys suggest I go with and where can I buy it?
Put down 548/502 on the dynojet at Twenty First Century Muscle Cars
Search is your friend. There's a current thread about this very topic.
http://forums.corvetteforum.com/c6-f...od-gauges.html
This is what I use and love it.
http://www.dashtronix.com/site/e9b26...ector_LIU8.php
Most electric guages for fuel pressure are like $200+, these are really cheap, are they any good?
http://pages.ebay.com/motors/link/?n...d=350653829192
Platinum Supporting Vendor
We have the C6 Dual Pod and fuel/boost gauges. This is the same setup we typically use for in-house installs. All in stock.
Dual Pod C6
http://www.aacorvette.com/performanc...so4df5b7af4d84
Fuel
http://www.aacorvette.com/performanc...roducts_id=138
Boost
http://www.aacorvette.com/performanc...roducts_id=137
Fuel rail adapter fitting for fuel sending unit so you can hook it to stock rail.
http://www.aacorvette.com/supercharg...roducts_id=361
Instructions from website.
http://www.aacorvette.com/pdf/aa_c6_...structions.pdf
Dual Pod C6
Fuel
Boost
__________________
Thanks, Josh Dodson
PLEASE TAKE A MOMENT TO VISIT OUR NEW WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
A&A CORVETTE PERFORMANCE
477 LAMBERT ST Ste A
OXNARD CA 93036
(805) 278-4107
Instagram @aacorvettesuperchargers
• Facebook.com/AACorvette •
Thanks, Josh Dodson
OXNARD CA 93036
(805) 278-4107
What I am curious about is how do you get the wires from the pillar pod down though the dash? I pulled my pillar cover off and did not see how I could fish the gauge wires down. I would appreciate anybody explaining how that is done.
Ok, I have the Autometer A pillar dual gauge pod with boost and fuel pressure gauges. DSVettes leather wrapped the A pillar gauge pods. The boost gauge is hooked up and functional. The fuel pressure gauge is wired to light up.
Question: I've looked at your gauge instructions, but still am not sure how I hook up the fuel pressure gauge to the fuel rail? I have a "Maggie" M112 supercharger. Will your fuel rail fitting (-4 Female to 1/8” NPT Female Swivel Fitting) work? or do I still need some other type of adaptor?
Here's how my A pillar dual gauge pod looks.
Thanks for any info you can share.
Still have to run them through to the engine bay.
I think this is the adapter that you need on the Maggie rail. You can thread the pressure sender into the 1/8 mpt port on the side.
http://www.summitracing.com/parts/rus-640730
Post a pic of the fuel line connection at the rail for us to see.
Attachment 47711687
Attachment 47711687
Here's it's pulled back a little; does this show enough? if not, I'll have to try a little harder.
The adapter I showed you the link for will work, but in the second pic I see a little fuel port similar to the factory rail test port...but there wouldn't be enough room for our usual fitting and the sender right there.
Cruising
Three pod pillar setup
Hello I was wondering if anyone sells or knows where I can get a three pod pillar setup for my c6 base model corvette I need one without the hole for the a pillar speaker/ microphone thing. Thanks
