Ls7 boosted valvespring upgrade?
I will be putting a procharger D1sc on a stock Zo6 motor, just wondering if i should upgrade to a dual valvespring+ pushrods for reliability or are the stock ones fine, Any info appreciated...
I just had a D1sc put on my 08Z. They upgraded springs, and valves (added a blower cam as well). Done in Dallas at Dallas Performance. Power put down is insane. Make sure you upgrade your valves and springs bro...With even 4-6pounds of boost, you'll be making crazy power. It'll be a entirely different animal!
just curious...will you be having your heads done while you are at it?
I just bought a car with procharger 4.5#, blower cam, comp cams dual springs...runs unbelievable, but the previous owner did not do the head rebuild with new valves/guides...so I will be pulling those soon.
preventative maintenance as far as I am concerned.
With more and more LS7s being modded latley, we have been seeing a number of exhaust valve failure due to guide wear. I personally know 2 guys this has occured to with medium power (~600 rwhp) and the repair equates to a new motor.
