And it starts again....
Just thinking out loud. Are you going to run into the same problem as Bretblownz06(needs more air) to utilize that 434.
F-2 procharger????????? Or do you think the F-1 stronger then the Ysi???
That being said with the deal i got on the motor.. It was worth it to me rather than building a smaller cube 4 bolt motor. And worst case if 950ish doesnt make me happy, down the road ill drop some nitrous on it or an f1x.
EWP arrived.. waiting to pick up the heads from the machine shop.. and then the build starts.
I think the 434 is to big for the f1r... And if i was trying to go for a max effor build i would most def need and f1x or and f2.. This motor came out of flyingmedica z06 that made 1300+ with an f2.
#37
Because street car
against the advice of a lot of people and looking for a streetabile and docile setup.. not going for max power..
i kept the filter on my F1R, Stock intake and stock catback...
here is the Stock NPP closed.. Sorry for the lighting.. Iphone at night
finally finished after adding a Dewitts radiator and high output alternator
but you can hear.. closed it's very docile and quiet..
http://s526.beta.photobucket.com/use...afde8.mp4.html
http://s526.beta.photobucket.com/use...98ca9.mp4.html
#40
