C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
[First nitrous install] LS3 with NX 90mm plate system
Old 07-17-2012, 11:26 AM
JUIC3D
JUIC3D's Avatar
St. Jude Donor '11-'12-'13-'14
Default [First nitrous install] LS3 with NX 90mm plate system
Hey CF,
I have an LS3 cam-only vette that I race on the regular and I wanted to try my hand at adding nitrous to my car.
I went with the NX 90mm plate kit, purge, progressive controller, fpss,etc
Here are some pics from the install. The main nitrous feed line is way too long so I'll be cutting off the excess and adding the fitting so it isn't so messy.
Comments, critiques, and thoughts are welcome. Thanks!
All the goodies(almost)
Initial solenoid placement but it was way too busy. I ended up ordering custom lines to clean up the install and mount the noids together.
The fuel line is still 1" too long so I have another line on the way to clean up the lines running from the noids to the plate.
Fuel rail tap and FPSS
Bottle mounted to pressboard, sandwiched in between the insulation and rear carpet
Nitrous Outlet switch panel wiring
Tapped into the VSS, tach signal, and TPS wires at the ecu so I didn't have to run wires everywhere in the engine bay
Nitrous feed, battery positive(1 gauge), wideband, timing box, and all nitrous wiring go through these holes in the firewall.
There are essentially 2 tunes loaded in the car and they change at the flip of this switch, thanks to resistors used to set the ECT to exactly 237* which allows a whole new timing map to be written
I also relocated the battery to the rear hatch compartment in preparation for the standalone fuel cell to take its place up front
HP Tuners interface, NGK AFX wideband controller, and Maximizer 4 progressive controller all secured in the glove box.
I didn't want to have to fuss with filling the bottle so I bought a mama bottle for the garage
Lastly, I ordered a new custom plate
ClashBandicoot (08-09-2016)
Old 07-17-2012, 01:09 PM
Detoxx03
Detoxx03's Avatar
Looks prett good. How much are you going to spray and what plugs are you using? Tuning yourself? Oh and what fuel are you going to run in the standalone?
Old 07-17-2012, 01:15 PM
JUIC3D
JUIC3D's Avatar
Thanks.
BR7EF plugs are in and the car seems to run fine on the n/a tune still.
My local nitrous guru buddy did the tune but it hasn't been on the dyno yet. I'm still doing some street pulls to make sure everything is working correctly.
It only has a 75 shot in it right now and I may try the 100 pills if the fuel pump can handle it. It's highly unlikely that I can go to the 150 shot(ultimate goal is 200) without increasing the fuel delivery so until then, I'll keep it mild. I'll likely just run 93 octane in the standalone as I'm not trying for a crazy shot.
Old 07-17-2012, 01:22 PM
Detoxx03
Detoxx03's Avatar
Originally Posted by Justinjor
Thanks.
Good I'm glad you are running non-projected tip plugs. So many people run the other crap with nitrous and it's not good. Should be good with 93 in the standalone on a 75 shot anything over a 100 I'd run atleast 109. When I used nitrous I ran C16 in the standalone but I started spraying at 150 then eventually went to 250 via direct port lol.
As long as you have the right plugs, correct amount of timing pulled, and fuel supply you'll have a lot of fun with nitrous. It can be very addicting though so watch out.
Old 07-17-2012, 01:23 PM
Seadawg
Seadawg's Avatar
Very nice! I may be over near Tampa the 1st week of August, so I'll PM you as the trip finalizes. I'd love to see it in person, to give me future ideas for my setup.
Ron
Old 07-17-2012, 01:24 PM
JUIC3D
JUIC3D's Avatar
Ya the 75 shot feels ok--I can barely feel it. It feels like the vtec in my wifes Honda Civic. There are a few places who sell race gas at the pump so we'll see. I want to run a 150 shot which should put me close to 700whp/700wtq which is about the limit of my transmission so we'll see how it goes.
I'm already having fun with it even though it's a small shot.
Old 07-17-2012, 01:30 PM
DSteck
DSteck's Avatar
I would shorten the fuel line between the nozzle and the solenoid as much as you can. That'll help with the lean spike on the hit.
Old 07-17-2012, 01:32 PM
JUIC3D
JUIC3D's Avatar
Thanks Dave. Ya, I have a 1" shorter line on order from NX. I had them custom make the 3 main lines but one was still an inch too long.
Aside from that, what else can be done about the lean spike? On the hit, it goes to .96 lambda and then falls down to .84 within about .15 of a second. That doesn't seem like very long and I'm not overly concerned with it, but is this something the standalone will address?
Old 07-17-2012, 01:58 PM
DSteck
DSteck's Avatar
Standalone will help, but having the solenoid only a couple inches from the nozzle is the best way to combat it. You've got nitrous at ~1000psi versus fuel at ~55psi (actually more like 45). The nitrous will move a hell of a lot faster, so making it cover more ground before it gets there helps.
150ms at too lean with a ton of cylinder pressure is enough time for things to go kaboom.
Old 07-17-2012, 01:59 PM
Detoxx03
Detoxx03's Avatar
A 75 shot it nothing. Wait until you get those 150 jets in.
Old 07-17-2012, 02:03 PM
JUIC3D
JUIC3D's Avatar
Hm, I guess I don't understand. The Nitrous outlet kit and most, if not all, of the other installs I've seen have the noids in the same place. With that in mind, I guess everyone has a lean spike on the hit?
Old 07-17-2012, 02:07 PM
DSteck
DSteck's Avatar
Yep.
I am extra cautious in everything I do, so take that for what it's worth.
Old 07-17-2012, 02:09 PM
JUIC3D
JUIC3D's Avatar
Yep.
Good info Dave, thanks for sharing. I too, am cautious, so I'll check into some other options.
Old 07-17-2012, 02:27 PM
jsnolan
jsnolan's Avatar
Nice..
Can't wait to see what kind of numbers you can put down.
And keeping it clean under the hood
Everyone says it's an addiction, just one reason I haven't done it yet.
I am afraid I wouldn't stop pushing.
Good luck with yours.
Can't wait to see a pass with a 150 shot....
Old 07-17-2012, 05:22 PM
carlrx7
carlrx7's Avatar
St. Jude Donor '08-'09
Thanks.
If you haven't already purchase a standalone. I have this in garage, bolts in using stock battery hold down.
PM me if you're interested.
-Carl
Old 07-17-2012, 10:43 PM
dennis50nj
dennis50nj's Avatar
love the tag
Old 07-18-2012, 08:17 AM
FloydSummerOf68
FloydSummerOf68's Avatar
The 9's will be welcoming you soon
To [First nitrous install] LS3 with NX 90mm plate system
Old 07-18-2012, 08:35 AM
winters97gt
winters97gt's Avatar
Car is going to haul the mail, Justin. As one of the best 1/4 drivers here, you should be putting down some killer times soon. Just run slower than a 9.68, and we are still friends.
I'll shoot you a pm later today in reply to our conversation
Old 07-18-2012, 08:36 AM
JUIC3D
JUIC3D's Avatar
Thanks Dennis..now I just have to wait for it to show up. The tax collectors office said 60-90 days..that was a month ago..
How's your car doing shawn?
Old 07-18-2012, 10:04 AM
JUIC3D
JUIC3D's Avatar
I would have to knock a full second of my current best of 10.67 to get there...
could a 150 shot, twin disk, and 3.90 gears be the ticket? I doubt it, but we'll see
Quick Reply: [First nitrous install] LS3 with NX 90mm plate system
