7 second true street c6Z build starts now!
#241
still finding leaks in the frame rail.
these three little slots for some harmless trim turned into huge holes to fill underneath.
data logger / g meter arrived from Joe @ Hyperaktive with a buch of sensors and bs3 interface
and a fresh late model water pump
#243
Looks good.
Anyone ever remove/cut out that front bar? Or swap it out for tubular? I want to cut at least 1/2 mine out and box it in to fit more room for FMIC/filter.
#245
I cut mine down to place FMIC where I wanted. But I didn't take that much off as I didn't need to etc... Lookin good David!
#246
#250
#257
radiator (before -20 fittings) from DeWitts
question of the day, anyone use one of these? is there a more compact offering directly behind the starter gear? (powermaster 9500 series) 9509 is the lsx flavor
considering this color wrap 'frozen black chrome'
p.s. i am looking for a forum sponsor to cut me a deal on all led conversion for the car (some interior lighting will not be used) looking to cut amp draw measurably.
#258
Yeah I used one of those Powermaster starters worked ok I didn't have a million miles on it, but it didn't really give me any issues. I needed it on my TT F-body because of the extra space and the infinite adjustablity. But on my C6Z I used a late model truck starter. it was WAY smaller and had the same plug that the factory starter used. ACDELCO-19180529 if your just looking for a smaller one. might take a look at it. was considerably cheaper than the stock unit. I was going to cut the plug and put a ring terminal when I found this one pretty cheap. Looking good!
#259
i need maximum clearance ahead of the lower section of the starter.
i also looked at the truck starter, and the powermaster is shorter still by about an inch
#260
Cool deal, just giving you the few options I had looked into. I run the truck one as it worked great for my little TT set up. Keep us updated, its starting to take shape finally.
