Update to "Best Rollbars" -- NHRA LEGAL
Former Vendor
The NHRA rulebook states "All vehicles with OEM frame must have roll bar welded or bolted to frame".
To my most recent knowledge, this rollbar is the ONLY one that conforms to the rules.
Regardless of claims by other manufacturers, if it doesn't attach to the frame, it's not legal.
So how does it work with the aluminum framed cars?
So this is for steel framed cars only correct?
Former Vendor
I looked through all the pics, but didn't find exactly what you're wanting to see. The sidebar is very close to the door at the top, by the handle, and by your leg/foot, to give you the most room possible. I can verify the side bar will pinch your fingers severely if you grab the wrong part of the door handle to close it and you'll only do that once.
WWW.HOXXOH.COM
480-283-7334 from 9-4:30 M-F MST
WWW.HOXXOH.COM
Former Vendor
Z06 also.
The blocks for the Z06 that the rest of the rollbar bolts to, are machined from 6061-T6 aluminum, so they can be welded to the Z06 frame. The bolt holes have stainless steel helicoil inserts to avoid galling and seizing from multiple installs and removals.
WWW.HOXXOH.COM
WWW.HOXXOH.COM
Great. Maybe next time I'm in AZ I'll swing by and grab one.
Z06 also.
WWW.HOXXOH.COM
WWW.HOXXOH.COM
Out of curiosity, are you doing a C5 version at all? I have a friend who's very interested.
can i just buy a 4 point?? bare. no powder coat. and make my own door bars. by the pictures. once you shut the do it looks like the bar is going to be rubbing my rib cage.
maybe try and get some more pictures.
Received 2,062 Likes
