OFFICIAL A&A SUPERCHARGERS Q&A thread
#461
Platinum Supporting Vendor
If it's good enough for your engine it is good enough for your supercharger. We currently use the new GM Dexos 5W-30 in-house.
#462
Why do your install instructions for the boost a pump for the supercharger kit on a C6, call for the deletion of the rheostat? I was in a car today they had the booster pump mounted under the hood with the rheostat a foot away. Install was done by a very very reputable tuner? I plan on doing a DIY install soon and just want to make sure I understand this totally?
#463
The setup you saw might have been an old install or just someones way of doing it. We prefer to mount the BAP in the left rear quater panel away from heat and close to the fuel pump connector. It works great.
#464
Thanks for the feedback , ill be running 100% meth injection. I think they will try to get it around 750ish
#465
Might have already been answered but I have a Tial 50mm BOV I plan to run with my T Trim C5 kit and I was wondering which spring would be best for the Tial?
#466
They do make a soft 3psi spring for SC applications if you want it to be open at idle and part throttle, but some guys like the stiffer spring so it doesn't sound like a street sweeper when just cruising at part throttle.
Select the following spring pressures based on engine vacuum reading.
"Version 1" Tial 50mm BOV:
-24 to -26 in/Hg use Brown - 13 PSI spring
-22 to -23 in/Hg use Yellow - 12 PSI spring
-18 to -21 in/Hg use Plain -11 PSI spring
-14 to -17 in/Hg use White -9 PSI spring
-10 to -13 in/Hg use Black -7 PSI spring
0 to -7 in/HG (or supercharger) use Green -3 PSI Spring
"Version 2" Tial Q/QR BOV:
-22 to -24 in/Hg use Brown- 12 PSI spring
-20 to -21 in/Hg use Yellow -11 PSI spring
-16 to -19 in/Hg use Plain -10 PSI spring
-12 to -15 in/Hg use White -8 PSI spring
-8 to -11 in/Hg use Black -6 PSI spring
0 to -7 in/HG (or supercharger) use Green 2 PSI Spring
Here is a link to help you and others out.
https://www.extremepsi.com/store/pro...roductid=17674
#467
I don't carry anything for the Tial, but...
#468
I have a bone stock c6 with an m6 ls2. I'm planning on buying your black kit with the v3 si head unit. I wanted to go with the 3.6 pulley. Will this be ok since it's stock exhaust? Will my clutch survive as long as I'm not doing hard launches just highway pulls? What kind of power could I expect with the stock exhaust with this pulley? Hoping for 550whp thanks
#469
#470
Hey Josh, I am looking to upgrade to a bigger S/C and I'm wondering whats the biggest best charger I can install in my bracket kit? I am not sure what charger is on there already, its an LS7 kit and it's self contained oiling. I am going to build a stronger short block and I want to gain more HP by running a bigger charger/more boost...I don't care if I have to plumb it into the oil system and I don't mind if it has that s/c whine to it either......
#471
Email me with more details about your car and what you have already so I can make you an estimate.
Josh@aacorvette.com
__________________
Thanks, Josh Dodson
PLEASE TAKE A MOMENT TO VISIT OUR NEW WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
A&A CORVETTE PERFORMANCE
477 LAMBERT ST Ste A
OXNARD CA 93036
(805) 278-4107
Instagram @aacorvettesuperchargers
• Facebook.com/AACorvette •
Thanks, Josh Dodson
OXNARD CA 93036
(805) 278-4107
#472
ls7 build
Hey josh, I ordered a self contained si-trim kit for my 07 z06 with a 6 rib & 3.8 pulley, we are running your stage 2 blower cam, tsp 285cc heads, FAST 102, KoOKs 1 7/8 headers, and a snow performance stage 2 meth kit. What kind of boost are you expecting us to produce ? Also how much boost can we run efficiently before we need to upgrade to the 8 rib setup? We are currently in the process of installing a forged rotating assembly so I'm just trying to get our ducks in a row.
#473
Usually the 3.4" 6-rib pulley is where you find out of it will belt slip or not. If you forge the pistons then do a 8-rib conversion and bigger blower at that time. Twin disc clutch, twin pump fuel system, 50mm BOV, etc.
#474
Cruising
Hi A&A guys,
How much boost i'm suppose to have with a 3.4 pully on a LS2 with V3 S-TRIM (kook headers and no cat).I have actually 12 pds of boost at 6500rpm. I make 575rwhp on a Mustang dyno, is it a good option to change throttle body . Thank
#475
I would however consider adding octane to that high level of boost. Like a AlkyControl Meth kit or E85 tune. Just see what your Tuner is comfortable using. Remember stock LS2 compression is 10.9:1
#477
I have a 2005 Vette with stock LS2 engine using you V3-Si kit with a 3.8" pulley and KB boost a pump and a Borla axle back exhaust kit. (2.5" dia.). On a 93 octane tune, it makes 552 rwhp and 476 ft-lbs torque with a maximum on 9.5 psi boost.
Does this torque level seem low?
I'm looking for more power and torque.
I'm considering 1 7/8" long tube headers and non-catted X-pipe and going to 3.6" blower pulley with a retune and still using 93 octane gas. Will I need to upgrade the in tank fuel pump for this mod? Are there any alternatives so I won't have to upgrade the in tank pump? Will this still be relatively safe for my engine.
What can be done to increase low to mid range (2500-5000-rpm) torque?
What can be done to improve engine longevity assuming the stock short block assembly?
#478
Most guys don't need and my base kit comes with the 6-rib setup and works great.
#479
The headers and 3.6" pulley with shorter belt would be a nice gain with the re-tune and would probably put you at 600rwhp. But, I always tell guys to consult with your Tuner first to see if they are comfortable pushing it to that hp on just pump gas. Also ask them if they have seen the stock pump and BAP make it that far. I would think you will be borderline and might run out of fuel pressure at that level. We have a really clean and simple external single pump fuel system if you just want to make sure you are covered on the fuel. You could also remove the BAP if you install the external pump setup and be good for 750rwhp. Check with your Tuner as he might even recommend meth injection at that level. It would be a great way to increase octane and keep the stock pistons happy. Just remember a stock LS2 is already 10.9:1 CR
#480
That hp and tq seem right inline with what I'm use to seeing. That all seems right to me.
