C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
LS2 - 402 with Andy's Supercharger Kit - Interesting Results
Old 02-13-2012, 10:00 PM
0C_Williams@RPM
Former Vendor
C_Williams@RPM's Avatar
Default LS2 - 402 with Andy's Supercharger Kit - Interesting Results
We took the opportunity to dyno the engine prior to install. Bear in mind that the base engine is a 9.5:1 compression blower engine.
What makes it interesting is that you see how efficient Andy's kit is.
Old 02-14-2012, 07:25 AM
JMBLOWNWS6
JMBLOWNWS6's Avatar
Graph looks really good. What vortech headunit? You can have alot of fun at that power level
Old 02-14-2012, 09:33 AM
0C_Williams@RPM
Former Vendor
that was a YSI - the owner will ultimately push the boost up. Heck, with the current pulley we could have made more by running it up to 6800.
Old 02-14-2012, 09:41 AM
JMBLOWNWS6
JMBLOWNWS6's Avatar
Way more in the tank! With a 3.250 I hit 900. Im so impressed with the YSI.
Old 02-14-2012, 11:44 AM
FloydSummerOf68
FloydSummerOf68's Avatar
Those are nice numbers with only 9.5 compression.
700+ is an animal on the street
Old 02-15-2012, 09:50 AM
0C_Williams@RPM
Former Vendor
thanks...the customer loves the power delivery...
Old 02-15-2012, 09:52 AM
0C_Williams@RPM
Former Vendor
You are so right -- the YSI is a great supercharger
Old 02-15-2012, 06:28 PM
Res1cue
Res1cue's Avatar
Heads??
Old 02-15-2012, 06:48 PM
0C_Williams@RPM
Former Vendor
Originally Posted by Res1cue
Heads??
Trick Flow - 6-bolt cathedral
Old 02-15-2012, 08:13 PM
Res1cue
Res1cue's Avatar
I have a YSI on a 403 @ 9.6:1 with very similar NA numbers. Max psi was about 750rwhp at 17.5lbs. I am running the 243heads with only seat work though.
17.5lbs on your setup look like it would be in the high 800's. I was told by the motor builder the heads were causing a restriction resulting in the lower numbers.
Old 02-16-2012, 02:28 PM
Josh@AandASuperchargers
Platinum Supporting Vendor
Josh@AandASuperchargers's Avatar
Great results Charlie!
__________________
Thanks, Josh Dodson
PLEASE TAKE A MOMENT TO VISIT OUR NEW WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
A&A CORVETTE PERFORMANCE
477 LAMBERT ST Ste A
OXNARD CA 93036
(805) 278-4107
Instagram @aacorvettesuperchargers
Facebook.com/AACorvette
Old 02-16-2012, 07:44 PM
0C_Williams@RPM
Former Vendor
thanks...we couldn't do it without you guys.....
Old 04-05-2012, 12:34 PM
HC Mechanic
HC Mechanic's Avatar
Really nice torque curve for a F/I setup, looks like fun!
Always nice to see comparisons too!
Old 04-05-2012, 12:51 PM
venomws7
venomws7's Avatar
Very nice numbers on both N/A and after S/C the gains are amazing with only 11psi..
Great work RPM and A&A like always
To LS2 - 402 with Andy's Supercharger Kit - Interesting Results
Quick Reply: LS2 - 402 with Andy's Supercharger Kit - Interesting Results
