Lethal Performance Big Red TTIX 21 PSI 1176HP
#161
im not specifically chasing a particular Dyno number, but like anyone with a heartbeat, I have expectations. Not spending 50K to just be happy with anything. I'm good with 1,020rwhp on E85 on a 90 degree day. I did expect to make at least 1,100rwhp based on the specific parts and what other state they were able to accomplish (these people claim 1,200rwhp). I'm happy with 100 less and expected that. I'm not very far off my 1,100rwhp goal and still happy with my 1,020.
However I'm trying to explain that I'm not fine with the power and torque suddenly dropping off like this. That is not acceptable. I'm sorry if I caused any confusion.
#162
Never changed ny mind. What is it with you? Just saw that there are others out there making 1200 and was hoping for more than a thousand rwhp. Not happy that power and torque take a dive at only 5,500RPMs though. Pretty confident the large link in the inlet pipes are the culprits.
3-4 times a year in Arizona. Plus Ca, midwest, etc.
Only reason I brought up other turbo cars was to show a LS turbo t3 based car can carry power to redline and make 1200+ like the OP said he wanted. Now he changed his mind (even though he posted time and time again he wanted 1200) so whatever. There are t3 options that can support the power, and that is all I was showing. The 5 bolt housings on the TTIX kit won't do it, but there are plenty of other t3 housings that flow WAY more than the old school 5 bolt housings which are about the worst turbine housing out there.
#164
Chris Stewart with a similar C5 TTIX setup did tests and found that the intakes weren't a real restriction.
#165
Received 1,194 Likes
St. Jude Donor '15
I can't see it dropping that hard or being that rough of a graph once it's falling off if it were hitting an airflow limit, but what do I know
#167
The kinks in the intake piping were made as per my request (INCREDIBLY STUPID, I REALIZE THAT NOW). I was very upset that I couldn't turn my wheel all the way left or right since I have the Centennial Edition ZO6 with ZO7 package which has wider front wheels. The TTIX was intended for a normal C6Z.
When I turned my wheels, they rubbed against and caught the piping. I then requested the shop (the one in NY) to cut my pipes down slightly. They cut them down to exactly half size to avoid the rubbing.
I'm nearly sure that's the culprit and that it's my entirely my fault.
Been waiting on the shop in Tampa to get back on my car to custom fab oval shaped intake pipes and then finish Dyno tuning it. After a few delays at the shop, I'm told they will get back on it this coming Wed or Thurs. let's see if that happens and I get my car back before 2017.
#168
Supporting Vendor
In order to know if you're maxed out, it's important to take measurements. Throwing parts at it until it makes power will get expensive in a hurry. Measuring pressure at the turbo outlet, the manifold and the exhaust manifold before the turbo would help along with the IAT's and AFR. Acquiring all this data will help you figure out if your intake is, in fact a restriction or if it's back pressure from the smaller turbine housing causing it. I would also recommend capping the turbo inlets and pressurizing the entire system to make absolutely sure there are no leaks. A visual inspection doesn't always tell the whole story.
Bret
Bret
__________________
Offering products from A&A Superchargers, East Coast Superchargers, Mechman Alternators, Mantic clutches, RPS clutches, Kooks Headers, Lakewood, LG, Brian Tooley Racing, Comp Cams, FAST, ARP, UPP Turbo systems, Wiseco, Callies, K1, MAST Motorsports, Haltech and many more. PM me for details.
