C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Dallas Performance Direct Port Methanol Injection
Old 02-14-2012, 09:19 PM
0Taylor@DallasPerformance
Former Vendor
Taylor@DallasPerformance's Avatar
Default Dallas Performance Direct Port Methanol Injection
Well if 2 are better than 1... 8 must really be better
I've been wanting to complete this setup for a while but it's finally finished. It's no secret that fuel doesn't like to turn. This takes care of a lot of the crap shoot that goes on with a traditional single or dual nozzle meth injection setup. We are using 8 nozzles in this configuration - 4 per bank with a distribution block on each bank. Very similar to a mechanical alcohol injection setup.
I'd highly recommend this combo for guys that are wanting to heavily rely on meth injection as a fuel source. I'd be willing to bet that most of you guys are.
Old 02-14-2012, 09:23 PM
Corvette-Chris
Corvette-Chris's Avatar
St. Jude Donor '08
Looks amazing, Taylor.
Are you still feeding it with the typical AlkyControl pump?
Old 02-14-2012, 09:29 PM
JMBLOWNWS6
JMBLOWNWS6's Avatar
So I take it you can get really aggressive with the timing with this direct injection? Since Im use to seeing the IAT effect from the meth and gains how would you judge the gains on this direct injection kit since it is downstream of the IAT sensor directly into the cylinder. Not knocking it Im asking because Im interested. And Im getting prepped to do something close like this on a ZR1.
Old 02-14-2012, 09:37 PM
GAMEOVR
GAMEOVR's Avatar
Flawless Victory!! Looks great man.
Old 02-14-2012, 09:43 PM
Former Vendor
Depends on what you are doing with the system. Not difficult to locate an IAT sensor across from the meth injection nozzle in this system if needed.
You can also run a pressure gauge on the methanol system in the car to monitor.
You can add a small 9th nozzle to still enable a temp drop across the IAT sensor located in the charge tubing.
Etc.
Old 02-14-2012, 09:46 PM
JMBLOWNWS6
JMBLOWNWS6's Avatar
Thanks for the reply Taylor. Its really looks nice. Do you have this going on any of your monster builds?
Old 02-14-2012, 09:49 PM
Former Vendor
Sending this to a customer in Germany along with a pallet of parts and then flying over for tuning later in the year.
Old 02-14-2012, 09:55 PM
JMBLOWNWS6
JMBLOWNWS6's Avatar
When your good at what you do it comes with rewards. Post the pics when done.
Old 02-14-2012, 10:33 PM
1320IN9
1320IN9's Avatar
thats FING INSANE !!!!
Old 02-14-2012, 11:45 PM
busaetr
busaetr's Avatar
Taylor, have you put any thought into running two nozzles in the charge pipe and tapping into the rails? Just use a fuel solenoid and activate it how ever you want.. Of coarse this would be on E85.. This way you never have to worry about keeping the tank full.. Something to think about, and if the 60 psi base isn't enough psi for meth nozzles you could use single nozzle fuel nozzles..
Old 02-15-2012, 12:20 AM
Detoxx03
Detoxx03's Avatar
Thats an amazing looking setup.
Old 02-15-2012, 07:55 AM
chuntington101
chuntington101's Avatar
Taylor, have you done any testing on how this compears to charge pipe mounted jets? Have you thought about mounting the jets higher up in the intake track to give more time for the meth to evaperate?
Chris.
Old 02-15-2012, 08:36 AM
DSteck
DSteck's Avatar
How do you think this would work with water injection? I use a meth system for IATs only, and will actually end up running pure water out of two M15s. I'm just curious if the water would vaporize enough in that short of a distance to the cylinders.
Old 02-15-2012, 09:01 AM
DTH STR
DTH STR's Avatar
So that's why you've been so quite lately!!
Shahram
Old 02-15-2012, 10:15 AM
jthurik
jthurik's Avatar
wow looks great .... its things like this is why I have no extra money... This will be in my future.
Old 02-15-2012, 12:03 PM
Flash20
Flash20's Avatar
do it john!
Old 02-15-2012, 12:25 PM
White_Lightning
White_Lightning's Avatar
Originally Posted by Flash20
do it john!
you know it will go on with his F1X
To Dallas Performance Direct Port Methanol Injection
Old 02-15-2012, 12:57 PM
Mr.Big
Mr.Big's Avatar
Old 02-15-2012, 01:05 PM
White_Lightning
Originally Posted by Mr.Big
Dallas/Valley Ranch Tx
1070+rwhp930+rwtq Boost ONLY
Dallas Performance custom F1R system, D.P. Forged 370, ALKY Control/D.P. 11 nozzle, D.P. E85 fuel system, Wilson Billet intake, D.P. Direct Drive + 10rib, WCCH 317's, D.P. Blower cam, HPTuner, D.P. '09 rearend, TR6060, Mcleod "sintered" twin, THANKS to www.dallasperformance.com
Fixed your sig for you
Old 02-15-2012, 01:11 PM
FloydSummerOf68
FloydSummerOf68's Avatar
Is it wrong that the first thing I was impressed with were the super-sexy welds?
Very nice looking setup.
Quick Reply: Dallas Performance Direct Port Methanol Injection
