AtomicFusion at the Shootout in Indy!
Hey everyone, we are at the shootout in Indy. Come by and say hello. We went out testing with the new setup last night and the guys at IPSMotorsports.net did a great job setting up the car.
Bob at AllPro heads came to the shop and helped Tommy put together what I believe is the best combination we have ever had in the car.
Last night we made some test hits at Muncie Dragway and the car was going faster on 11psi that it used to on 15+ !
Come out and say hello, and watch as we try to set new records this weekend!
Well, we are qualified last so far... first qualifing run was an 8.15@177. We are making some changes and hopefully will be much faster tomorrow.
Procharged F1X 7.18 @ 197
St. Jude Donor '09-'10-'11
You mean the ERL motor?
Well, we kicked a rod out the block today on our 3rd qualifing run. Loaded up and heading home now.
There is always next year.
Our oil down was nothing compared to the one done by the car after me.... almost everything we had went into the diaper/pan.
There was a car sent down before I made it back to the pits, and then that car broke and the track was down long enough for me to load up everything and pull out of the track.
