Fuel pressure dropping to ~50psi even after KB BAP (630whp LS3)
I posted before about how my fuel pressure was dropping to ~45psi on the stock fuel pump
( http://forums.corvetteforum.com/c6-f...i-too-low.html )
so this is just a follow up FYI about how the KB BAP did after it was installed. It was installed w/ the Racetronix harness and wired to give 100% power after 3psi, no **** control. The A/F ratio isn't posted since it was just recorded using LogWorks and monitored via my in car wideband, but it was in the mid 11's. The fuel injectors are FAST 65lb/hr @ ~90% duty cycle.
Seems like a fuel system upgrade may be needed before I go any further w/ a cam install.
I made ~540wtq across the midrange
I'll have to look at that RSI system... if I'm going to be spending the money and going through the pain in the *** to swap the pump, i'm thinking about going with something big that can handle ~850+ rwhp on E85, since I'm sure that's where the car will end up eventually and I don't want to have to do the job twice.
Same HP maybe, but I'd love to have your torque
BJK
Former Vendor
Location: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
http://www.aacorvette.com/supercharg...products_id=66
We'll need bigger pics of your avatar before we can ship it though.
We got one that will work perfectly for you.
http://img33.imageshack.us/img33/4470/photo6lj.jpg
http://img850.imageshack.us/img850/9...inkyellow5.png
That looks like a nice system and I like no tank dropping.. sounds like I use my BAP still too? Can it and the stock components that still remain in the system flow 850whp worth of E85 though?
Former Vendor
One thing I've learned so far is that you can tune the car fine on 45-50psi of fuel pressure, I'm just not sure how safe that is as you get into the higher hp ranges.
