The twin turbo Z06 build from Hell finally done!!
Former Vendor
It's nice to see this car finally coming together. A little more time on the dyno and it will be good to go
Also fwiw, no pulls were made at 13-1 a/f ratio.
I'll update this thread next week with final #'s and dyno sheets.
A bit of good news for you...
With 454 CI, the cam profile you specified, the Compression Ratio you listed and the turbos you listed, You'll max out those turbos before you need race gas........ You should clear 1050 RWHP on pump gas NO PROBLEM!
Sound like a nice project, but quite the ordeal, glad you have deep pockets to see your project through!
Sucks that you hooked up with so much incompetence at the start of this project.
Make me feel blessed that I have a best shop in Canada less than a couple miles from my home.
Good luck with any further endeavours!
Dyno numbers are up
Updated on 10/3/11
Well Jim spent all day last Friday and even stayed late to get the car done.
Jim set up the boost controller with presets at
SP1 6psi 592rwhp 573rwtq dynorun 25
SP2 9psi 690rwhp 654rwtq dynorun 27
SP3 13psi 815rwhp 803rwtq dynorun 31
SP4 15.5psi 878rwhp 899rwtq last run on 110 Oct Fuel
Updated on 10/3/11
#34
I live 3hrs from Chicago and I’m heading out this weekend to pick the car up. So I don’t know it hooks up with 9psi yet.
#37
Your boost controller is one of the better boost controlers that is able to do bbg. I would def give turbosmart a call and findout what need to be done. Spinning 1,2, and 3rd all the time is just not fun to me. But how you have better luck on the 18s. Ill let you know if I get any more info on it also.
#38
I will give turbosmart a call and see if they have come up with anything yet. I went with the 18" to try to help with traction and maybe I should have done 16" in the rear.
#40
815 on pump gas seems really conservative for such an involved build.
It seems like that motor should be putting down a lot more power?
Very nice build though. I bet it feels great.
