E Force - Florida
Go Canes!
OP was pretty clear. Central Florida (usually means Orlando).
I know of 2 good ones in So Fla, although I am yet to do mine! You also may want to contact Motorhead-47, he is in the Panhandle, though.
I agree about contacting Motorhead-47.
PM him and he can give you good advice as he is very knowledgeable about the e-force
good luck on your search. Love my e-force
You are more than welcome to PM me for advice as suggested above but I highly recommend you search out a local “brick and mortar” well established local shop with a solid reputation for Corvette work. You don’t want some shop who has never done this install before using your car as their guinea pig to learn on. It is not a complex install but has to be done right. IF you do not find a suitable local shop I can do the job. I am a skilled experienced hobbyist...not a mechanic by trade. I would need the car over a 3 day weekend to knock it out and you and I are 5hrs/350 miles apart. Local would be a better option IMHO.
Location: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
Received 1,464 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Assistant wrench on stand by if needed.
Next Level Performance should be able to handle this without any trouble. I've worked with Geoff several times before I know he's plenty competent with both the installation and tuning aspects.
