E-Force Supercharger on 2010 GS
#61
With what blower? Thats going to make a difference. And as there is no application specific unit available for this, there are ALOT of variables when it comes to the heat exchanger he is using. Results im getting so far are not mixed at all, it does what its been doing for years on the mustangs. Lowers IAT's and quite well. The chiller mixed with spraying a 50/50 mix of water/meth in the lower intake is working quite well.
#62
http://forums.corvetteforum.com/c6-f...iat-temps.html
#63
Interesting... Because when I contacted Kincaid performance (manufacturers of the killer chiller) about this almost two months ago they specifically said they had no system in the works or in development for the C6 but they could custom build one for me if I supplied them with the A/C schematics. Thats when I took it into my own hands. So that leads me to believe that his system came from somewhere else? Dont know enough about his dealings to comment, only what I was told by them directly.
#64
#66
Guess that solves that..... So it wasnt even Kincaid that was involved.. That could be why the results were mixed, system wasnt built correctly for all we know. Its tough to say. From what ive seen so far though, it works very well. Im hoping that after I present my findings to Kincaid they will bring a C6 version to production. I really feel that for the money they would have a strong market here.
#67
Looks like the C6 one was the "Super Chiller"...not the "Killer Chiller"
Link to a Camaro install with photos... http://www.camaro5.com/forums/showth...killer+chiller
#71
Thanks again Hutch!!
Just had the car dyno tuned and picked up a bit more oomph over the off-the-shelf tune that comes with the supercharger, plus the car feels a bit "snappier" in the mid-range, probably a result of more torque.
529.75 RWHP
496.32 FT-LBS TQ
Again, you can get more power with other systems out there if that is your goal but I'm very pleased with my car's performance and excellent street manners. Hey, it works for me!
529.75 RWHP
496.32 FT-LBS TQ
Yea, I was REALLY impressed, I got to experience it first hand. I drove my stock 2011 GS from Daytona to Orlando (about an hour), romped it a few times to be sure I knew the "feel", then got into Hutch's ride with him. A VERY noticable difference in the seat of the pants acceleration, when he romped it.
And, literally NO noticable difference in sound, driveability, handling manners, etc. AND, the engine oil and water temps were similar to mine, and it was close to a 100 degree day for the ride. No noticable heat soak or loss of power. Again, on the street and not flat out, but that is what 99% of my driving would be too.
I'm very glad I took the opportunity to meet Hutch and take him up on a ride offer. And I have a lot of respect for this SC setup now too.
Thanks again Hutch!
Ron
#73
Very cool!
Thanks again Hutch!
Ron
Thanks again Hutch!
Ron
#74
Thanks again Hutch!
Ron
Thanks again Hutch!
Ron
#76
The reason I chose Eforce..
Do you plan to track and/or drag race your car regularly? If the answer is no, then you won't have an issue with heat soak and the Edelbrock supercharger. If you track your car regularly then IMHO you don't want a supercharger at all....of any type. If you are addicted to drag racing, buy a centri.
If you want to talk more about temperatures and the Edelbrock supercharger, I've been running one for over a year now. I'm assuming you are asking because someone has put the myth in your ear about PD blowers and heat soak?
ALL cars (modified or not, carb’d or fuel injected, normally aspirated or forced induction) experience some form of heat soak. The most common form of heat soak occurs when you shut down the car on a hot day. In the absence of active cooling (water circulating and air flowing) the entire mass under the hood will try to come to a common temperature. Because the engine is the largest mass, everything else attached will tend to migrate to the temp of the engine…typically around 200 degrees. As soon as you start the car again and begin rolling down the road you have water circulating and air flowing across the coolers…heat soak goes away. On supercharged cars, the most common and misused form of the term is when you put the car into a state that it can’t quickly recover from the heat soak….typically this occurs with repeated full throttle pulls on a dyno with inadequate airflow (lousy fan) or when drag racing with back-to-back hot laps on a hot summer night. So what’s the result when this happens?...the car senses the high temps, reduces timing to keep from damaging the engine and you lose horsepower (temporarily) as a result. Sustained high speed driving on a track while in boost on a hot day can also get you into heat soak mode. What happens with the dreaded heat soak mode?...once again, the car senses the high temps, reduces timing and horsepower falls off until your cooling system recovers.
So if you plan to spend all of your time driving on the dyno in the summer, street racing in Mexico, hot lapping at the local drag strip or competing at Sebring you probably should worry about heat soak… with a supercharged or any car for that matter.
For the rest of us….it really is a non-issue. I’m willing to bet a beer that the heat soak phenomena is/would be transparent to 90% of the members on this forum.
P.S. I also live in Florida and it gets hot here!
#80
Orlando
Thanks for posting your experience with the shops in Orlando.
It seems they do excellent work! Awesome.
I am planning an e-force installation before I return home from Afghanistan in December.
Orlando is not to far from Miami and gives me another option besides a recommended shop in the Miami area.
I am planning to give them a call and or e—mail.
I have gotten quotes for the unit itself but nothing with the installation.
Frank
Frank
