Whipple C6 Vette SC system
#141
Supporting Vendor
St. Jude Donor '09
Absolutely gorgeous setup. It looks like the Halltech Super Bee is our fiberglass version. Same massive 15" Halltech Filter. I think your email to me indicated that our intake reduced vacuum by 2", and decreased IATs by 6-8 degrees?
I did not see our Beehive heat shield in the pictures, was it in place? It shields the filter from underhood heat, and with some slight cutting in the radiator shroud area, will bring in ram air. We typically see ambient plus 2 degrees on the road within 150 ft of a one minute stop.
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
262-510-7600
For service email:
orders@halltechsystems.com
www.halltechsystems.com
262-510-7600
For service email:
#143
#144
#145
#148
Yes. Instant Boost and I mean instant. With some kits you are hitting full tq at 2000rpm's... Fun on the street doesnt get any better, No waiting for boost , no spooling, no bs...
#149
wow thats awesome.. but how does it compare with the procharger centri system?
the zr1 basically has a tvs2300 pd blower so there must be a reason they went with this blower style.. unless they choose it because it was more astetically pleasing through the clear window of the hood
#151
that hood look great in the updates pics! I had this same Whipple 2.9 on my GT500 and these blowers are amazing!
Dustin, do you see any belt slip issues when running higher levels of boost? Say 15-16psi? It looks like the kit is using a 6 rib setup?
#153
#154
p sent Dustin.. IF YOU for some reason dont get it please pm me back and let me know.. i left you my phone number as i dont like comunicating over the interwebs when something this important is involved.
#157
Working on the new 4.5L compressor now. It is a brand new compressor for us so we do have a lot of testing to do before it is released. At this time, I do not have an accurate release date but it should be be within a couple months.
#158
Hey Mike. Are the ls3 kits shipping yet? Are you taking orders? Any dynos on c6 ls3 to post?
#159
Lots of dyno graphs of the Camaro version on the Camaro5 board. Same blower and LS3 motor....should yield similar results. Maybe a little better with the vette's lighter drivetrain. The Camaro does have a slightly different motor on the A6 versions. Little less compression and vvt. Most of those guys get rid of the vvt and convert to an LS3 style valvetrain.
#160
But it's going to retain the same bolt spacing and such so a direct swap?
