RR-Stage 1 Twin In-Tank Fuel Pumps
Supporting Vendor
Ragin Racin has developed a new solution to your fuel problems. Our twin in-tank system alows you to maintain stock drivability and noise levels until your higher fuels demands are needed. Our all aluminum billet fuel pump bracket houses 2 Walbro 255l/hr fuel pumps for fuel needs up to 1000hp or you can upgrade to 2 Aeromotive Stealth pumps if more fuel is required.
Our supplied custom wire harness allows you to run both pumps simultaneously or have the second pump activated by a boost reference switch.
*NOTE* - This setup is for 2003 1/2 - Present Corvettes
Fetures Include:
Stage 1 - Includes
Fetures Include:
- Twin In-Tank Fuel Pump with Filter
- Custom Billet Aluminum Bracket
- 2 Walboro 255l/hr Pumps
- Complete Plug-N-Play Wire Harness
- Quiet operation unlike large Intank Pumps.
- Quickconnects for factory in-tank fuel lines
- Fuel Level Sensor Bracket
Stage 1 - Includes
- Regulator
- Hoses
- Mounting Hardware to utilize fatory fuel rails and lines
- All Plug N Play
__________________
RAGIN’ RACIN’
Randy Leger
337-278-8397
sales@raginracin.com
http://www.raginracin.com
RAGIN’ RACIN’
Randy Leger
337-278-8397
Supporting Vendor
We just finished up a 2004 Stage5 C5 A4 today that we installed our Stage 1 fuel system on after running into fuel issues on the dyno. The graph shows how well our system took care of the problem.
