Dallas Performance / APS Twin Turbo - Build Thread with pics C6 Z06
#61
Former Vendor
Not sure why anyone would spend the energy to reproduce these housings? Our custom kits use standard housings.
Yes we have been looking into making cast manifolds that will use standard T3 housings (not T25).
#62
I've always been fascinated by that wild external wg piping setup, but is it really needed?
#63
Former Vendor
At lower pressure ratios sure. As you push the turbos harder it really needs the external gate.
#65
Former Vendor
Note you will love all the new power and it is very flexable just turn it up for more power. Mine made 663rwhp 576rwtq at very low boost. Now I'm just looking for some traction!
#68
Former Vendor
Pictures coming. Tony did not have the optional Akrapovic X-pipe so we modified a stock C6 Z06 H-pipe we had laying around the shop. Basically just shortened the H-pipe, welded on the APS flanges, and connected the Akrapovic catback
#70
Former Vendor
We finished up the install of the twin turbo kit, and Tony has picked up the car. We imagine he’s out driving in the great weather we have had. Here are the last pictures we took after the installation was complete. You will notice that the charge pipe has been slightly modified. After discussing with Tony and receiving his approval, we sanded down the lettering and black coating and had the charge pipe painted body color to emphasize it in the engine bay, and also to tie in better with painted intake manifold cover. We also had some of the surrounding panels for the intercoolers powdercoated black, so they didn’t take attention away from some of the other details under the hood.
The painted charge pipe:
The pieces we powdercoated black can be seen on the left of this photo:
Slightly over-exposed, but hopefully you can see some detail in the darker areas:
Everything all tidied up underneath:
Modified factory H-pipe with the APS flanges:
Below is an overlay of the baseline dyno and the TT dyno, showing a healthy 174 whp / 141 trq gain over the baseline. Keep in mind, the baseline dyno had an intake and longtube headers. On a stock ZO6, our APS install would give you almost a 200whp gain, with stock like driveability, a great torque curve, and the ability to grow to 1000+ whp with a built motor and fuel system.
Uncorrected dyno chart:
And finally a quick video of Tony’s car on the dyno: http://www.youtube.com/watch?v=eoyjDbCv4oo
We would just like to thank Tony again for giving us the opportunity to install this kit on his car. We know Tony had the choice to take his vehicle to any one of the several shops in the DFW metroplex that work on Corvette’s, and he trusted us to work our magic on his beautiful car. We hope you enjoy your new found power, and remember we are just a phone call away if you need us.
For anyone else interested in one of the two remaining APS twin turbo kits, call us at the shop so we can schedule a date to install one.
#73
Very nice power numbers and it looks great. Are you running just off waste gates springs to get that 6lbs boost or do you have a controller? Can I see your air/fuel graff? I was only running at 5lbs and might kick it up to 6lbs to get that 600ftlbs TQ. Very nice Job.
#74
Former Vendor
It's running off the wastegate spring - no boost controller. Should be the same boost as yours if you are running off the wastegates. The dyno uses a sensor that reads up to 72psi so it's not super accurate at such low boost and could be more like 5 psi peak. It's mainly used for reference from one day to the next of for before and after changes.
#75
Also did you retain the front brake air ducks if so how? Did you mod the duck work?
#77
Loving the car...It's lots of fun. Had it at the Capital One Spring Classic in Plano on Saturday.
Let me know when you have some creative boost gauge ideas for me!
#78
For those interested, the car will be on display at the Dallas International Auto Show starting this Thursday and going through Sunday afternoon.
http://www.dallasautoshow.com/
Look for the Lone Star Corvette display section.
