Asking all you HP shops? A.P.S engine question.
Have the 2008 ZO6 putting the A.P.S turbo's on it. Motor is stock. I've herd of them droping valves/ valve springs. If I keep the boost down to ? LBS presure what if anything do I need to do or should do to the engine? I'm not forgeing it going to build another motor for that in future. Just need to know if it would be wise to up grade anything minor on the motor for now to run the turbo's and what hp to expect to shoot for?
Does anyone know how much weight this will add to my car?
What would be the first thing or most efective to help reduce the weight gain I have a carbon hood? Would like to get it back to stock weight.
Thanks,
Thanks,
Former Vendor
Thanks,
Thanks,
Stock pistons are the next weak link...
What valves are in it stock?
Couldnt agree more. Deff do the exh valves. Cant hurt to do springs since half of them will be off anyway for the valves. Keep the AFR rich to save the pistons.
Former Vendor
As already mentioned, the inlets on the C6Z kit are excellent. The standard C6 kit is another story...
Would be happy to tune it for you, just say when
